webmail https redirect
ssgill
Hello, trying to figure out how to serve webmail on https always. If http is typed it doesn't redirect to https. I have tried most of the suggestions in forum, setting up "ssl_redirect_host" settings
added to /usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-includes.conf
<location /*>
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
</location>
But nothing works, any help would be appreciated.
Thanks for helping out, just want to update that these 3 custom build options did worked redirecting to server host for all domains
"use_hostname_for_alias", "redirect_host" & "redirect_host_https"
But maybe this is not what i want, webmail url on domain is what i was looking for.
Will follow the link provided and see if that works.
these files need to execute the rewrite command,
da build rewrite_confs
so...
It's should work, but you just adding in the wrong directory, if you want to testing before put in the customize mechanism, you must insert into "/etc/httpd/" directory.
Normally when a domain has ssl it works automatically with the browser.
You could probably use the force_ssl=1 parameter in directadmin.conf but keep in mind this would automatically force all domains to ssl. In some cases that might not be requirable.
