Does DirectAdmin have cardDAV and calDAV server support?
IT_Architect
Does DirectAdmin have the equivalent of cPanel's "Calendar and Contacts Server" so that contacts and calendars can sync across their devices using RFC standard cardDAV and calDAV? I know that RoundCube can be configured as a client to support it.
You can install Nextcloud in your DA en do cardDAV and calDAV support
You are free to google it or write your own ;)
@zEitEr, the point of the question is to find out if anyone has succeeded with a functional integration and if there are any negative points, certainly Google will give answers, but I prefer to refer to the DA community (not that I don't want to make the effort of searching on Google or with AI, but to benefit from feedback.
I appreciate this community for its spirit of sharing, like the @Active8 and @smtalk suggestions, which allow me to consider other solutions.
Why wouldn’t you like to use JMAP instead of those? :)
Please can you elaborate this a little bit? More and more customers are asking for it. I saw on the site https://jmap.io/software.html that the feature is planned for dovecot. But what would that mean, that it will be native available from this point, or is it just a hint for programmers as you are, to write their own implementation?
JMAP is the likely successor to CardDav. JMAP Calandars/Contacts could be used instead without added complexity from CardDav/CalDav servers. It is not yet provided together with DA, but.. if I personally had to choose between them - I'd go JMAP way :) Some software like https://stalw.art/ come with JMAP support by default. Dovecot had it in its plans for a very long time, but nothing from them yet... (a proxy could be used to solve it with Dovecot)
this would be great.
we have moved hundreds of clients from cpanel to directadmin, and some have reverted back because of this. very few, but still.
