opcache directadmin plugins
MisterM
Hello
As my subject indicates, is there a plugin that manages Opcache on the server as under plesk?
no, but you can make your own custom opchache.ini file if this is what you need:
First you copy file over.
mkdir -p custom/opcache
cp -p configure/opcache/opcache.ini custom/opcache/opcache.ini
Then make and save any changes to opcache.ini
nano custom/opcache/opcache.ini
Then run
./build opcache
Any changes in opcache setting will now survive any updates
Well my question would be why did DA decide to alter the default opcache values? Seems ridiculous to have to create a custom file to reinstate the default opcache values.
