TCP_OUT block port but still works.
mikussikus
Someone can be able to explain me why port 465 works on my server? I don't have set this port in TCP_OUT and TCP6_OUT. When I use below command, it works. In ConfigServer Security & Firewall I have founded these parameters.
SMTP_BLOCK = ON
SMTP_ALLOWLOCAL = ON
SMTP_PORTS = 25,465,587
openssl s_client -connect smtp.gmail.com:465
Do you try it as a super user root? Or a regular user? IF the first, then it is regulated by:
Bash:
tcp|out|u=0 # Added by DirectAdmin
udp|out|u=0 # Added by DirectAdmin
in /etc/csf/csf.allow
Additionally the following.
I'm nog 100% sure if this makes any difference but you have:
SMTP_BLOCK = ON
but this was a 0 and 1 way by default.
So if the users can pass, maybe you can try this instead:
SMTP_BLOCK = "1"
SMTP_ALLOWLOCAL = "1"
it's also like this in the original default csf.conf file so maybe it makes a difference.
and can say any non-zero value is treated as TRUE, i.e. 1.
Ah great. I already stated I wasn't sure about it. But it's good to be sure, thanks for testing and at least now we're sure it won't make a difference if you put on or "1". Then I can remember that for next time.
But now I'm confused. Isn't the SMTP_ALLOWLOCAL = ON allowing the traffic anyway? Because clients connect with their mail program to the server, that is incoming port 465, not outgoing. And then Exim sends them via port 25 outside to another server.
Because port 25 is also in there as is port 587 which aren't blocked either right?
So maybe you have to remove port 465 from the SMTP_PORTS list or remove 465 from exim to block it incoming.
Edit: I just read somewhere, removing port 465 from SMTP_PORTS and not having port 465 in tcp_in and tcp_out should block incoming 465 traffic.
Is that save when I remove 465 from SMTP_Ports ? thanks
If you don't want port 465 to be used anymore then I would advise to remove them from SMTP_PORTS and also from TCP_IN and TCP_OUT as far as it's present.
Also it would be good to create a /etc/exim/variables.conf.custom file and add:
daemon_smtp_ports=25 : 587
and then recompile Exim and exim.conf again.
However, I don't see any reason to disable 465 as even the big ones (MS and Google) are using them, but it's your decision ofcourse.
Thank you so much
