The used space disk size is not correct.
phpmirza34
Hello
Can you look at the screenshot below?
Disk Space Used: 56.61 GB
BUT
My sites average 12 GB
my directadmin panel
/admin_backups = empty (I cleaned it)
/user_backups = empty (I cleaned it)
/trash, tmp = empty (I cleaned it)
It hasn't been fixed yet after 24 hours. I don't have 56 GB of space. I'm using 12 GB. Where are these extra files?
I look forward to your help, thank you.
you need to check it from ssh console, maybe you have somewhere archive/files owned by this user so it counts to global quota even if files in different paths. also it counts database size
I looked at the MySQL files. The MySQL files are not large.
How can I check with SSH? Can you give me information? Or is there a source?
for partitions: df -h
for all folder sizes for the current directory recursively: du -h
Hi my friend
I connected to the terminal via ssh.
I emptied this folder. This is how I found the solution.
So you need to find out why the /backup directory is getting full and regularly delete the old files.
Moreover, storing backups on the same server just defeats the purpose.
Well I keep a backup on the same server, different drive, and a copy on another machine. I don't want to have to wait for 4 TB to transfer before starting the restore if I don't have to. We don't know what the situation is with phpmirza34.
I agree. It doesn't make sense to keep backups on the same server.
I solved the problem. I had started an automatic backup before. A complete server backup was taken. I deleted it and made space.
