Difficult password enforcement setting not saved
urgido
MX
Hi
I am experiencing a random issue. I am unable to save the option Difficult password enforcement(Security Settings > Security tab), Does anybody has same issue? The checkbox always is unchecked.
DA Version: 1.679
thanks
You might open a ticket with DA support and let them investigate the issue.
Meanwhile you can run the command in CLI as root:
Bash:
da config-set enforce_difficult_passwords 1 --restart
to achieve the same result.
