High cpu usage
mikajaxxx
Hi
my cpu load goes above 50
the main reason seems to be this process:
/usr/local/directadmin/directadmin legacy-handler --config=data/admin/runtime.directadmin.conf --xfs-on-domains --syslog
it cosume all cpu and cause slow server
anyone could tell me how to disable this?
The main reason is MySQL as far as I can see from your screenshot. MySQL can be overloaded because of several reasons:
1. ddos attack/httpd flood/vulnerability scanners/search bots/seo bots/etc
2. badly written script
3. malware
The directadmin legacy-handler is a directadmin process, you should not want to stop it)
More reading:
- https://docs.directadmin.com/webser...ch-engine-crawlers-are-increasing-system-load
- https://docs.directadmin.com/other-...db-mysql/general.html#how-to-track-mysql-load
- https://docs.directadmin.com/other-...leshooting.html#mysql-queries-cause-high-load
- https://docs.directadmin.com/webser...ow-to-track-which-site-is-producing-high-load
or hire somebody to fix it for you.
as i investigated the main reason is --xfs-on-domains --syslog which maybe is related to xfx disk quota & writing to log file
could you help me to disable this feature?
Thanks for your attention
i folow your instuct as i see the only process with 283 s time is da_admin
The subject was already discussed here on the forums many times. So if you want to troubleshoot it on your own, you would need to read existing threads and suggested documentation. Some threads, where I participated too, already have step-by-step instructions, they did not change since years.
so the problem is directadmin?
please give me the query to search in forum to solve this
tnx again
i check the mysql process list & even suspend all users to see where is the problem the only user have hi time is da_admin with around 1244.
but the cpu load is still high
so if the mysql is ok the problem should be because of this on?
i am searching for this issue all around the internet nothing found
Ok i found the solution by your help
i add these codes to directadmin.conf
use_syslogd=1
disk_usage_suspend=0
now the cpu load is gone !!!!!!!! its now around 2
i can't believe the solution was such easy. please inform the directadmin support to address this problem about directadmin.
If directadmin writes too much logs, then you would need to investigate why is it so.
The real reason is probably that directadmin tries to block IPs, and fail. Just a guess...
Hello again
still /usr/sbin/mysqld use a lot of cput around 300% !
the processlist command is absolutely normal but the mysql still use alot of cpu. how i can track the problem?
please give me an straight answer.
Best Regards
High MySQL usage can mean a lot of things. If your running a bunch of WordPress sites you should use a cache plugin, been finding the Surge cache plugin to be decent and simple. If you have a lot of tables/databases you may need to optimize your my.cnf config a bit. A good tool for that is MySQLTuner ( https://github.com/major/MySQLTuner-perl ), it can help you, use it as a guide, don't 100% copy every recommendation it gives. Also make sure you have enough RAM, low ram can cause some serious performance issues. Also good idea to adjust your kernel swapiness, I keep mine at 1 to keep the system from swapping and only swap if it's going to OOM. Also very importantant if your doing custom code and making your own databases ta add indexes to everything that is searched, can really increase lookup speed. This is just some suggestions, much more information would be needed to give a specific recommendation.
