FortressMB
- Jul 2, 2025
First, I'm running:
Ubuntu 24.04
Directadmin
CSF/LSF
Have not gotten any further to install anything else.
I am trying to change the SSH port to an uncommon port. Lets call the port 1234.
I have changed the port in /etc/ssh/sshd_config to "port 1234"
I added the same port number to the TCP in/TCP out in Firewall configuration.
I saved and restarted all
Port 1234 is listed as the port for ssh when you do the "server check-->Check SSH on non-standard port"
Does NOT show in the "View Listening Ports" and when I try to putty in i get connection refused. SSH is running because I can putty in on 22 still. Have not blocked it yet.
Any ideas what I am missing or might be causing this? New to DA.
Thanks,
Mike
First, I'm running:
Ubuntu 24.04
Directadmin
CSF/LSF
Thanks,
Mike
