DirectAdmin 1.679
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.679.
DirectAdmin 1.679
Would a 24 or 48 hour notice that a new version is forthcoming be beneficial?
It would be for me, but I'm just one. Would it benefit others?
Just to be clear, I'm not talking about hotfix releases, just major releases. Just for major releases, like when 1.680 is pushed out, "We expect to drop DirectAdmin 1.680 in two days on July 15, 2025"
Just a suggestion.
A new DirectAdmin build for version 1.679 is released. It fixes mailbox conversion issue in the cpanel to directadmin migration script.
A new DirectAdmin build for version 1.679 is released. It fixes filemanager add to clipboard issue.
1.679 sürümü için yeni bir DirectAdmin derlemesi yayımlandı. Dosya yöneticisinin panoya ekleme sorununu düzeltir.
After the latest update, extracting ZIP files in the file manager doesn't work. The "Extract" button is not becoming active.
Everything seems to work correctly for archive extraction in both Evolution and Enhanced skins on our test servers. This could be something specific to your server. Please open a support ticket at https://tickets.directadmin.com.
DirectAdmin 1.679
Good afternoon.
I'm sorry, I may not have seen the changes in the list, so I'm asking. Has the Ukrainian translation been updated in this version? Because the Ukrainian translation is 100% on the https://translate.directadmin.com/projects/directadmin/-/uk/, and my hosting provider has pop-up messages in English that are not translated at all:
Reply Sent
Your ticket number is 000000012. Keep it for future reference.
Backup creation added to queue
You will receive a message when it's complete.
Cannot create User Backup
You have used 110% of your disk usage, which is more than the allowed threshold of 90%.
P.S. Found information about the control panel version. My hosting provider has installed DirectAdmin 1.668 :(
I wrote to the technical support of the hosting provider with a request to update to the new version.
I have a question: in which version after 1.668 was the Ukrainian localization/translation updated?
Tech support wrote that for some reason the auto-update fell off or something. ./build update directadmin current v1.668 1d67cc75fde69a15f51a7b3f8c46fdef7cead628 is already latest
Maybe because of EOL OS ?
I did not understand your message. Did you mean that the hosting provider no longer supports updates on their own server?
If that's what you meant, then they (the hosting provider) replied that they didn't see any important changes there and there's no point in wasting time updating to the latest version! ((
there have many important change, if they don't.... then you might cancel the service and find the new place.
What I recall is if the OS outdated you cant update to the latest DA version, something i thought to because you were stucked to 1.668, we are now on 1.679.
EDIT
Ah found it : In case if your OS is based on RHEL 7 (CentOS 7.X or CloudLinux 7.X one), the latest DA version that is supported there is 1.668
More info here regarding manual update with CLI here
What I recall is if the OS outdated you cant update to the latest DA version, something i thought to because you were stucked to 1.668, we are now on 1.679. Or ask your provider to do an manual update by SSH as mentioned here :https://docs.directadmin.com/direct...ting-da.html#manual-update-using-cli-commands
As it turned out, they can do it all, they are smart guys. But most likely, they don't have the time or desire to do it. Therefore, they said they planned to do it in the future, but did not provide exact dates.
Question to the developer. Is it possible to update only the translation on this old version? Because it turns out that at the time of the release of update 1.668, the Ukrainian version was not fully translated.
