Reverse proxies using HTTPD config
jarred-Awesome
Hey Everyone,
My Directadmin is set up on a server that uses Apache, as opposed to NGIN. I can't seem to find a good guide on how to set up a reverse proxy using Apache.
Ideally I want the settings to look like this:
<VirtualHost 123.456.78:80>
    ServerName subdoamin.mydomain.com
    ProxyPass / http://123.456.78:8080/
    ProxyPassReverse / http://123.456.78:8080/
</vitualHost>
<VirtualHost 123.456.78:443>
    ProxyPassReverse / http://123.456.78:8443/
</vitualHost>
But I can only figure out how to do this:
    ProxyPass / http://123.456.78:8443/
</vitualHost>
</vitualHost>
I attahed a photo of how I did it.
Can someone explain the proper way to do this?
Maybe, if there is documentation of how those scripts work?
This is an example, but no link to what the actual scripts are doing.
Sorry, I am very new to direct admin
Which scripts? If you want to learn what are those directives mean, then you need to read official docs from Apache website.
I was refering to these conditions
|*if SSL_TEMPLATE="0"|
|?HAVE_PHP1_FCGI=0|
|?HAVE_PHP2_FCGI=0|
I don't think those conditional statements are standard apache. i can be wrong though
Yes, they are not from Apache. These directives are for DirectAdmin: TOKENs and IF-constructions.
You might start from here:
- https://docs.directadmin.com/directadmin/customizing-workflow/
- https://docs.directadmin.com/webservices/apache/customizing.html
- https://docs.directadmin.com/webservices/apache/customizing.html#using-a-custom-virtualhost-template
- https://docs.directadmin.com/gettin...for-nginx-openlitespeed-apache-configurations
and then search more information on "template" on https://docs.directadmin.com
