DirectAdmin 1.680
Thanks.
Can you enlighten this one a bit for me as I'm not native English and I'm not sure what is ment by "mail address" here:
Any forwarder email address can be used as a sender address if the forwarding rule is configured to deliver emails to the main address.
1.) So I have 2 forwarder emails.
One mail going to my ticket system is automatically also forwarded to my normal contact mail address. This keeps working I presume?
2.) Other situation. A customer has [email protected] and has his mail automatically forwarded to [email protected] for example.
Microsoft is often messing with from adresses, but it can also be gmail and this is a forward which is not going to the "main address".
It's not clear to me what happens in these 2 situations or what exactly changes with forwarders, would be nice to have an example for us non-English users.
I have a little question about Exim.
Is this still work if the user is owner of the domain, but can set any sender name, "{any_sproof}@user_domain" ?
To address lingering questions with additional Exim ACL:
  • User can always send email from address that was used for authentication.
Example: user authenticated as "[email protected]" can send emails from "[email protected]" address.
  • Domain part can be an alias domain that points to the main domain.
Example: if alias domain "alias.example.com" points to "example.com", user authenticated as "[email protected]" can send emails either from "[email protected]" or "[email protected]"
  • Local part can be a forwarder address from the main domain if it forwards to his authenticated email address.
Example: if "[email protected]" is forwarded to "[email protected]", user authenticated as "[email protected]" can send emails either from "[email protected]" or "[email protected]"
  • If catch-all points to his authenticated email address he can send from any local part within the same domain.
Example: if Catch All E-mail forwards mail to "[email protected]", user authenticated as "[email protected]" can send emails from "{anything}@example.com"
Oke so if I understand correctly, nothing changes as far as it goes for "normal" forwarding as in my 2 examples. Thank you.
While this setting can be disabled - which is probably what I will do - it just seems that this "feature" is overstepping the boundaries of SMTP.
In principle I can see where this is beneficial, but it really needs to be part of SMTP and not something that DirectAdmin takes upon itself to implement. I can see this causing a lot of issues for users who have been implementing their own sending policies with a single SMTP Authentication user.
That's just my opinion. But at least this can be disabled.
After server update from directadmin including soft i get the following error
Misdirected Request​
The client needs a new connection for this request as the requested host name does not match the Server Name Indication (SNI) in use for this connection.
The error occurs when a location in NGINX (proxy mode) is missing the following newly added directives:
                proxy_ssl_server_name on;
                proxy_ssl_name $host;
see:
Bash:
[root@srv custom]# grep proxy_ssl /usr/local/directadmin/data/templates/nginx*
/usr/local/directadmin/data/templates/nginx_server_secure.conf:         proxy_ssl_server_name on;
/usr/local/directadmin/data/templates/nginx_server_secure.conf:         proxy_ssl_name $host;
/usr/local/directadmin/data/templates/nginx_server_secure_sub.conf:             proxy_ssl_server_name on;
/usr/local/directadmin/data/templates/nginx_server_secure_sub.conf:             proxy_ssl_name $host;
[root@srv custom]#
you will need to add these directives either in custom templates (if they are used) or in directadmin on a custom httpd page (if only configs for selective domains are customized)
If you don't know how to fix it, contact me for a private assistance, you will be charged a fee in this case.
Have same issue like HageHosting, think there should be a warning or simple script added by DA if update affects config files in such way in future.
This works form me:
Bash:
#!/bin/bash
FILES=(
  "/usr/local/directadmin/data/templates/custom/nginx_server_secure.conf"
  "/usr/local/directadmin/data/templates/custom/nginx_server_secure_sub.conf"
for TEMPLATE in "${FILES[@]}"; do
  if [[ -f "$TEMPLATE" ]]; then
    echo "Processing $TEMPLATE..."
    TMPFILE=$(mktemp)
    awk '
      /location[[:space:]]*\/[[:space:]]*\{/ { loc_open = 1 }
      loc_open && /proxy_pass/ {
        if (!found_ssl) {
          print "                proxy_ssl_server_name on;"
          print "                proxy_ssl_name $host;"
          found_ssl = 1
      /}/ { loc_open = 0; found_ssl = 0 }
      { print }
    ' "$TEMPLATE" > "$TMPFILE"
    cp "$TEMPLATE" "$TEMPLATE.bak"
    mv "$TMPFILE" "$TEMPLATE"
    echo "✓ SNI directives added where needed."
  else
    echo "Skipped: $TEMPLATE not found."
  fi
done
echo "Reloading configuration..."
/usr/local/directadmin/custombuild/build rewrite_confs
systemctl restart nginx
systemctl restart httpd
This works form me:
Totally agree, even when people have custom configs DA totally just deploys the update without any warning. Still you run the updates yourself but a warning would be nice or unable to update until you fix the warning would be better than just running the install of the new version without warning.
The server running version 1.680 is currently experiencing an issue where the default sorting in the File Manager is set to Permissions and cannot be changed back to the previous behavior as in version 1.679. I have checked other servers still using version 1.679 with the Evolution skin, and they display the file list normally — sorted by name by default. This issue affects all users, not just a specific account.
Could this be a problem introduced with the latest update? It seems the recent change in the "New File Manager's files and folders table design evolution" might have affected the default sorting behavior.
The new Exim setting is affecting to MDaemon usage. For example, we have some customers using one email account for authenticating for all outgoing emails. So, the email for authentication is different than the email in FROM field. With this type of customers, the new ACL will stop all outgoing emails.
Putting the setting "AUTH_BLOCK_SENDER_SPOOFING = no" into /etc/exim.variables.conf.custom will change the whole server. Is there any way to use it for a specific domain in the system?
