Hello everyone,
I’m facing an issue when trying to change a reseller’s package using the DirectAdmin API.
Context:
Has anyone experienced this or knows what might cause this message? Is it a permission limitation, a DirectAdmin configuration, or a bug?
Thanks in advance for any help or suggestions!
Context:
- I’m authenticating with the API as the admin user (the main admin of the panel).
- I can successfully list resellers using the CMD_API_SHOW_RESELLERS command.
- I can also list available reseller packages using the CMD_API_PACKAGES_RESELLER command.
- However, when I try to change the reseller’s package using the CMD_API_MODIFY_RESELLER command with these parameters:
action=package
reseller=reseller_username
package=package_name
api=yes
error=1&text=Cannot execute your request&details=That reseller does not belong to you
- The username and password are correct.
- The package I’m trying to assign exists and was listed by the API.
- I’m authenticating as the admin user, which should have full permissions.
- I can see the reseller and packages in the web panel and haven’t found any restrictions preventing this change via API.
