modsecurity rule blocking my site from saving
rhett
My site is a woocommerce store built with Bricks Builder page builder.
DirectAdmin panel + litespeed web server, running on unmanaged VPS.
I found in modsecurity log below rule set blocking:
Blocking saving in Bricks settings:
932235
941110
941100
941160
941180
Blocking entering editor canvas and causing redirect to /my-account/page
933150
Blocking saving in editor canvas
932230
How to bypass the security for administrator's operation without disabling those rules completely, please?
I attached 4 ruleIDs blocking log in the attached link. Please have a look.
Do you meant... bypass those rules only for some user or domain ?
User Level -> Modsecurity should have the bypass rules ID interface.
Do you mean the user -> advanced features -> modsecurity -> disable rules?
To disable rule IDs in this way, those rules will not work when real risk/attach happens, right?
In this case, I wonder if it is possible to create a rule to bypass request based on url "/wp-admin/admin-ajax.php" and cookies "wp-settings-1" and "^wordpress_logged_in_"?
I don't kno how to filter base request on cookies, but if it request url, then you should put custom rules ( I don't know where to put it. )
If it comodo rules, it should have UI interface for put the custom rules set.
SecRule REQUEST_FILENAME "@beginsWith /wp-admin/" \
     "id:1001,\
     phase:2,\
     pass,\
     nolog,\
     ctl:ruleRemoveById=911100,\
     ctl:ruleRemoveById=932260,\
     ctl:ruleRemoveById=920340,\
     ctl:ruleRemoveById=932235,\
     ctl:ruleRemoveById=941100,\
     ctl:ruleRemoveById=941130,\
     ctl:ruleRemoveById=941160,\
     ctl:ruleRemoveById=941170,\
     ctl:ruleRemoveById=949110,\
     ctl:ruleRemoveById=980130"
Please adjust the remove id by yourself.
#note: this example rules will be global for all domain.
Try :
SecRule REQUEST_HEADERS:cookie "^.*wp-settings-1.*$" "id:123094610,phase:1,t:none,pass,log,ctl:ruleRemoveById=911100"
For request based on url just change
SecRule REQUEST_URI "/wp-admin/admin-ajax.php" "id:123091620,phase:1,t:none,pass,log,ctl:ruleRemoveById=911100"
do it for other rules , modify as you need
put that rules before this rules id
932235
941110
941100
941160
941180
Thanks for the help.
I've just solved the issue with the help from imunify360. They told me there are 2 rulesets in my system, which will cause high false positive rate and inconsistent rule functioning. The blocking rulesets belong to OWASP, so I've disabled OWASP in custombuild -> options.
Your welcome , yes i think enough to use ImunifyWaf rules only and disabled OWASP rules if to many false positive.
