DirectAdmin Installer variables
DrWizzle
Here
A new build is released. It fixes an issue in the Evolution menu customization page when trying to set a custom menu icon for a category.
I've just done another DA install, and the setup script threw out some more variables I didn't know existed. Are the DA_ADMIN_USER and DA_ADMIN_PASSWORD variables actually used for the admin when used? This could prove very useful.
Also what's DA_ETH_DEV? Asking as there's no mention of these on the install help page (unless it's in your to do list)
These installer variables allow changing the default admin account (used to log-into DA after installer is finished) user name and password.
Database password is always auto-generated. A custom database password can be used if ./conf/mysql.conf file is created before starting DA installer. In this case the credentials specified in this file will be used.
Short installer help is available with /usr/local/directadmin/scripts/setup.sh --help command.
When I defined the variables before running setup.sh:
Bash:
[root@alma-4gb-nbg1-2 ~]# export DA_ADMIN_USER=poralix
[root@alma-4gb-nbg1-2 ~]# export DA_ADMIN_PASSWORD=iMl***************Lmt
[root@alma-4gb-nbg1-2 ~]# export DA_HOSTNAME=server.example.net
I got: the following information has been set:
Bash:
  Admin username:     poralix
  Admin password:     iMl***************Lmt
  Admin email:        [email protected]
  Server Hostname:    server.example.net
If you cannot connect to the login URL, then it is likely that a firewall is blocking port 2222.
Nice)
Bash:
Bash:
Nice)
Cheers @zEitEr , I didn't have time to spin up another vps and try it. I think that's a cracking feature though as with those env variables, would be easier now to create install scripts to set variables to what I want. Really nice touch.
