mockingbird
- Feb 6, 2023
I know this s been covered before ad nauseum, but I could not find an answer for my issue.
I must have done the update two weeks ago, yet I keep receiving emails from LFD with this message:
Surely, some internal database within DA should have the corrected md5sum values by now, but evidently they do not.
I have automatic updates disabled, perhaps this is the reason? I would like to keep automatic updates disabled. So is there a way to force a refresh on the md5sum values so that the error goes away?
The following list of files have FAILED the md5sum comparison test. This means that the file has been changed in some way. This could be a result of an OS update or application upgrade. If the change is unexpected it should be investigated:
/usr/bin/da: FAILED
/bin/da: FAILED
