global blocklist domains for e-mail
freakie
Apeldoorn, Netherlands
i wanted to make a global blacklist in which domains are present from which we dont any e-mails.
we are using rspamd so i did this:
create the file in /etc/rspamd/local.d/blacklist.conf
contents:
reject_content {
type = "content";
filter = "full";
map = "/etc/rspamd/local.d/blacklist.map";
symbol = "REJECT_CONTENT";
score = 10.0;
prefilter = true;
regexp = true;
then i created the file /etc/rspamd/local.d/blacklist.map
contents:
domain1.com.
domain2.com
but this isnt working.
anyone gat an idea?
I don't work with rspamd so I have no clue if you definately want it in rspamd.
But if you really don't want mail from domains then I use the /etc/virtual/blacklist_domains file for that, then they are already blocked at Exim before spamcheck is even done if I'm correct.
Some form of wildcard and regexp can be used in there too if done correctly.
We do this via multimap, then you can see how effective the rule is in the web interface.
/etc/rspamd/local.d/multimap.conf:
BLACKLIST_SENDER_DOMAIN {
priority = 5;
type = "from";
filter = "email:domain";
prefilter = true;
regexp = true;
map = "http://patches.xy.nl/rspamd/blacklist_sender_domain.map";
score = 20.0;
require_symbols = ["!WHITELIST_IP", "!WHITELIST_SENDER_DOMAIN", "!WHITELIST_SENDER_EMAIL"];
action = "reject";
the contents of /etc/rspamd/local.d/blacklist.map
firets.nl
comaxe.cloud
pfxstormshelters.com
conuk.in.rs
allstarts.online
yagsep.site
cunjas.space
mabsge.store
cokimc.com.tr
/.*\.cyou$/
contents of /etc/rspamd/local.d/multimap.conf
priority = 5;
type = "from";
prefilter = true;
regexp = true;
score = 20.0;
action = "reject";
I checkd the rspamd logs and it seems to work, it blocks the domains.
if it keeps working i will distribute these two files in my network on other DA machines.
