DirectAdmin 1.685
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.685.
DirectAdmin 1.685
You know that that change broke our application for an hour? Why do you do that with php_ADMIN_value, why not just PHP_VALUE???? If I have Redis in my ONE application and other apps are using Files session Redis stopped working!
PHP:
ini_set('session.save_handler', 'redis');
if ($environment == 'production' || $environment == 'clone') {
    ini_set('session.save_path', "tcp://localhost:6379");
} else {
    ini_set('session.save_path', "tcp://redis:6379");
  • Like
Reactions: fln
Thanks for reporting it @ShinJii. The php_admin_value is used to make all PHP modes to behave the same (the php-fpm mode was always using php_admin_value).
I agree that there is no much benefit in enforcing it. It is strange we never got requests to relax it on php-fpm mode. We will investigate it further and most likely relax it to be a simple php_value instead of php_admin_value.
Thanks fore reporting it @ShinJii. The php_admin_value is used to make all PHP modes to behave the same (the php-fpm mode was always using php_admin_value).
Thanks :) we're using litespeed by the way.
The reason no any report yet,
I guest most of web dev just using "session_set_save_handler" function, so no reason to use that "session.save_path".
A new build is released. The php_home_tmp_session_save_path feature will use php_value instead of php_admin_value to keep the flexibility of changing it at script runtime. Thanks @ShinJii. The new build also fixes File Manager directory delete window showing NaN undefined message when the real directory size is not known, thanks @DrWizzle.
@fln can you fix php-fpm template too?
|*if PHP_SESSION_SAVE_PATH!=""|
php_admin_value[session.save_path] = |PHP_SESSION_SAVE_PATH|
|*endif|
to:
php_value[session.save_path] = |PHP_SESSION_SAVE_PATH|
|*endif|
@gurek this release already uses php_value instead of php_admin_value for all PHP modes and webservers that got support for session.save_path in this release. The PHP-FPM mode still uses php_admin_value, because it used it before this release. We do not want to make breaking changes as hot-fixes.
We will change php_admin_value into php_value in PHP-FPM template in the next release and document it as an update.
