If I remember correctly, the DNS-01 challenge relies on you having the domain's nameservers (and possibly glue) pointing to the server you're trying to issue a certificate for. You must also have DNS setup on the same server. This will aid you in getting a wildcard certificate for the domain in question.Hey all. Could someone please lightly nudge me toward where I can learn about the current most hassle-free method for using DNS-01 challenges during Let's Encrypt certificate renewal? Thank you in advance.
Correct. Unless you can use LEGO with your registrar.I believe you're only able to add specific records like www.domain.con, domain.com, mail.domain.com etc...
Yes, but that requires you to manually create the certificate in Certbot CLI iirc, by manually creating a TXT record that it gives you in the process. Not sure if that's auto renewable or not, I can't remember as I've only used it once or twice a few years back for a project. LE on DA is auto (for simplicity for users i'm guessing)Correct. Unless you can use LEGO with your registrar.
Maybe long time ago you did this? Or did I miss something? As far as I know you only need an access token from the registrar.but that requires you to manually create the certificate in Certbot CLI iirc, by manually creating a TXT record that it gives you in the process.
Yes, I have to admit is was many moons agoMaybe long time ago you did this? Or did I miss something? As far as I know you only need an access token from the registrar.
can also work with autossl.
