Run script rclone after done backup
mikussikus
I use rclone to transfer my users' backup to another server, however rclone script is running from crontab in specific time. Is exist any directadmin hook when I can be able to run my rclone script after da backup?
Have a look at this page here:
Gives you info on how to create a pre or post backup hook and the filename to use as well.
I added the all_backups_post.sh file and pasted the code I used in the crontab. I tested it, and everything works. However I have one thing, when directadmin finish backup and start my rclone script, monitor backup in directadmin still exist, when rclone will transfer all filles then da close the stream. It is correct?
As far as I know, DirectAdmin does not have a built-in post-backup interceptor. Alternatively, you can wrap the backup command in a script. Also try using cron, which runs shortly after a scheduled DirectAdmin backup.
