wp multisite - domains under different DA users
johannes
I did read, that the best option for wp multisite is to symlink the public_html directories. Its clear, if the domains are all under the same DA user.
But would it work, if the domains are under different DA users? Would it be enough, to adjust the user rights of the symlink? And whats about SSL certs then?
No, it would not work. No, it would not be enough. SSL is not an issue here. But permissions and open basedir will cause issues, and reading operations are the least ones. More issues might occur with writing operations.
WP Multisite is only really meant to be used on 1 domain, or 1 account with a shared database, redis and file/object storage. Splitting it over various accounts, servers and the like and you'll open yourself up to all sorts of performance issues and extensive maintenance as others have said.
What exactly is your end goal here?
Thank you all guys!
My goal is a SAAS ticket seller system for several ticket sellers, where we host the complete system on one wordpress, and each ticketseller get his own website, login, design, and can provide his ticketshop under his own domainname. It should bring us also hosting customers by this way, if they want additional services like email.
So if symlinks dont work in this scenario, then i guess also vhost configs (putting document root on other account) drop out of the game - right?
The last what i can think of, is, to leave them all on subdomains under our own main domain with the wp installation, and then map their domainnames with CNAME DNS entries to the subdomains. But i heard this can give probs with mapping the maindomain (without www), and makes it possible to only use www.domain.xy.
permissions and open basedir will cause issues in this scenario
Why not to host everything under the same directadmin account then? You don't plan to share SSH, FTP, DIrectAdmin credentials with the sellers, so it should not be an issue at all. Emails can be moved outside /home/
It was my intention to sell them full hosting services too, at least for them who want it. Email was just an example.
But its not a problem, I guess CNAMES will be the easiest way.
I dont know, if it will work. Never did that, never used CNAMES in such a scenario on our own server, but I hope to get the customer domainnames (their own, full domainnames) with CNAME on top of our WP multisite subdomains, so that they can use their own domainnames, but the multisite WP is still on our subdomains. Will try..
A CNAME record does not bind a name to a virtual host, as well as a site in a WP multisite environment. If you simply add a CNAME record pointing to any server's IP you will see either a default "is functioning normally" or a shared page.
If you need a working solution I could try and prepare one for you in your environment with real or test domains)
The idea was as follows: the WP main installation on a main domain as example ticketseller.xy, and the following multisites for the customers as subdomains seller1.ticketseller.xy, seller2.ticketseller.xy , all under one directadmin account. Then, seller1 could have his own domain www.mygreatticketshop.xy mapped with CNAME to seller1.ticketseller.xy. Additionally in WP multisite this records must also added for mapping.
No mapping to a server IP, just www-domains to subdomains. Would it not work? I saw this scheme often with 3.party SAAS servers and even added CNAMES for my customers using such services in our DNS.
Great offer, thank you very much! I must wait for my partner agency with this project. I also must test and try it out before, as i never did setup a WP multisite. I`d like to come back to your offer as soon its in work.
SAAS servers might have a default virtualhost for it that catches all requests, routes and process them as designed. A DirectAdmin webserver also have a default virtual host, that will catch all traffic that comes to domain names missing in virtual hosts. On directadmin servers it is a default "is functioning normally". For your case you can use a dedicated (private) IP for a user. In this case CNAME records might work as wanted.
