Which Operating System is most stable/common to use with DirectAdmin
@Hetzner DirectAdmin, could you please share more details (CB build log).
In general DA should work fine on Debian 13. We have not noticed any problems on our daily CI/CD integration tests (testing if CB components builds fine on every supported distro).
I certainly tried 17 times on Hetzner using Debian 12 and Debian 13 and always got an initial install error.
I finally threw in the towel and tried Centos 10 and everything installed correctly.
My question is..
Is there not a favorite OS distro that is most commonly used on shared cloud hosting, like Hetzner (who unblock email ports) that is used?
For example FREEpbx has recently recommended Debian 12 and provide a script.
Last year DA had a install page that showed 4 distros, but that page has been since taken down.
Once should consider that there is a flow of new Learners that are thinking more about email privacy and DirectAdmin Personal Plus package is just the best way to accomplish this.
However, if there is one little hiccup in the initial install, the newbie learner who might not have linux experience save for a couple youtube setup videos will be left with no recourse to this "new-century no privacy" reality that is now upon us.
Right....
I am tempted to try installing DA on Debian 13 with @DrWizzle swap instructions.
Is it recommended to do an apt full-upgrade ? Or just let the control panel do it at the Custom Build phase?
I spin up the VM first, install Ubuntu 24.04 and then update ubuntu. I'll then set the DA variables and run the install script. I've never done it any different so I couldn't tell you if the DA script would update your OS first.
