Solved Bug on this forum
DrWizzle
Here
@romans @zEitEr @fln Sorry to tag you guys here, but I don't know if the forum software has been recently updated? I'm unable to upload any attachments on my PC using browsers (Tried Firefox, Chrome & Edge) or the PC App, or iPhone to this forum. Therefore, I'm unable to illustrate one of the bugs on DA that still exists to be fixed.
I would ordinarily post a pic to illustrate this bug, but ironically a bug is preventing me reporting a bug 😁. Hoping one of you guys can fix the forum software, or direct this message to your IT dept and get it looked at?
Cheers!
And I had an issue with quotes. Looks like a quote limit. My post was refused without notice why, but I discovered it got accepted after I removed 2 of the 4 quotes. Very odd.
In the console, i'm getting a 403 error, Forbidden.
It's coming from the file 'core-compiled.js' and 'action.min.js'
Again, I can't Copy/Paste the data here.
99.9% Uptime, 100% Sarcasm. Cache me if you can!!
I have no issues copy and pasting.
Well I've no idea what's going on @Richard G , I tried copying from the console, wouldn't work. Tried copying from the console to Notepad to here and still wouldn't work so i'll just leave the fix to the tech team 😁
I can copy paste in the browser, just not copy paste images, or external text. Strange!
This is a test, written in notepad.
See if I can copy and paste this?
below paste from a forum.
ok kan men hier vragen stellen over de werking van het forum.
below paste from server console.
/dev/sda Serial Number: SAMSUNG
Maybe you need a new browser. :) I'm using Firefox.
But indeed, lets see if they can fix things.
Copied from a terminal
✔ 4f4fb700ef54 Pull complete 15.2s
✔ 453b597793ea Pull complete 17.2s
✔ 1e4731fffc43 Pull complete 17.3s
✔ 6e17268996a1 Pull complete 17.3s
✔ 1c777a2b8a33 Pull complete 17.3s
✔ dff6ffbb2968 Pull complete
Copied from notepad:
All docker applications have been added to the docker network my-main-net
If you add more docker applications to this server, make sure to add them to the my-main-net network.
You can then use them by container name in NGinX Proxy Manager if so desired.
@Richard G I'm still unable to post images, although selected copy/paste will work now. It's really strange!
Are you able to post images or attachments?
When trying to POST an image I get "403 Forbidden":
Request URL: https://forum.directadmin.com/attachments/upload?type=post&context[thread_id]=81071&hash=803xxxxxxb
Request Method: POST
Status Code: 403 Forbidden
Remote Address: 104.26.12.65:443
Referrer Policy: strict-origin-when-cross-origin
Thanks for letting us know. The root cause for the upload problem was the CloudFlare blocking the request. We have adjusted the CloudFlare security settings. Image upload should work now. Attaching a screenshot as a test :).
Thank you. Any clue on the cause for refusing multiple quotes (just like 4)? Was that the same cause?
Not sure, I was not able to reproduce the multiple quotes problem. If this problem is gone as well it is likely that CF was causing it.
@Richard G
Can you take the screenshot for example input ?
Before fixed the CF, yesterday I can't reproduce your issued too
