cannot allow TLS1.0, TLS1.1 in exim
Where? As far as I know only TLS 1.0 and 1.1 was deprecated, TLS 1.2 is used all over still.
Ok, I think I got confused that might have been 1.1 I was referring to.
If I may ask a quick question.
Referring to the DKIM Selector modification, to make a very minor change to /etc/exim.variables.conf.default
will the change be overwritten?
or do I have to do the change in /etc/exim.variables.conf.custom ?
This is one my last hurdle in the DA setup, but it is for personal reasons.
I tried:
nano /usr/local/directadmin/conf/directadmin.conf
then add
minimumtls=v1_1
Then i tried to edit the /etc/exim.variables.conf.default
openssl_options = removing +no_tlsv1_1
Then rebuild but it overwrote my config
So I guess I have to do the custom build thingy?
You're on the right track, but as for the exim.variables.conf.custom file, you only need to add what you want to change compared to the default.
Otherwise you might miss important updates of the other things.
So in the /etc/exim.variables.conf.custom juist copy the line you want to change, make the change, save and then build exim and exim.conf as you did.
then add
minimumtls=v1_1
There is no such setting for directadmin as far as I'm aware. There is a tls_min_version setting but that is only valid for tls 12 and 13.
That seems to have done it... for now
That's good news for you although every client I know understands TLS 1.2 so no need to go down to 1.1.
But still I would advise to use only the applicable line in the custom file.
