How to enable HTTP/3 with Nginx?
Pieter
I'm having trouble enabling HTTP/3 with Nginx.
Have compiled Nginx with the "--with-http_v3_module" \
Config located here:
/usr/local/directadmin/custombuild/custom/nginx/configure.nginx
Have tried the the following in my template:
# 1st attempt (not sure how to enable for IPv6):
listen |IP|:|PORT_443| ssl;
listen |IP|:|PORT_443| quic reuseport;
http2 on;
|MULTI_IP|
# 2nd attempt (hardcoding my IPs)
listen 1.234.567.89:443 ssl;
listen [2001:123:aaa:456:0:0:0:1]:443 ssl;
http2 on;
listen 1.234.567.89:443 quic reuseport;
listen [2001:123:aaa:456:0:0:0:1]:443 quic reuseport;
Added the header:
add_header Alt-Svc 'h3=":443"; ma=86400';
/usr/local/directadmin/data/templates/custom/nginx_server_secure.conf
Using (https://http3check.net/):
HTTP over TCP request to server failed, forcing my ipv4 results in QUIC is supported & HTTP/3 is supported
Using SSL Labs I get various warnings: 'Failed to communicate with the secure server' & 'Unexpected failure : No supported protocol found' & 'Unexpected failure'.
Reverting to my original nginx_server_secure.conf listening block:
http2 on;
|MULTI_IP|
brings back my A+ score on SSL Labs
Am I missing something?
Yes, everything rewrites and starts correctly.
Just started with a bare minimum nginx_server_secure.conf template and a single html file.
Noticed that the actual order of the listed directives make a difference.
http2 on;
Adding the Mozilla Intermediate SSL config to my nginx_server_secure.conf fixes some connections issues but this could be a coincidence.
Still I get random 'Server closed connection' issues with SSL Labs Handshake Simulation
