Solved Dovecot 2.4.2 on Alma Linux 9 compile failure
HageHosting
Get the following error when compiling Dovecot
@HageHostng, please check if you are using customised dovecot configuration script. Maybe you are enabling extra dovecot features there?
On our test servers the new dovecot builds fine on all supported Linux distributions. If you have no customizations please open a support ticket.
OS Version =
NAME="AlmaLinux"
VERSION="9.6 (Sage Margay)"
ID="almalinux"
ID_LIKE="rhel centos fedora"
VERSION_ID="9.6"
PLATFORM_ID="platform:el9"
PRETTY_NAME="AlmaLinux 9.6 (Sage Margay)"
ANSI_COLOR="0;34"
LOGO="fedora-logo-icon"
CPE_NAME="cpe:/o:almalinux:almalinux:9::baseos"
HOME_URL="https://almalinux.org/"
DOCUMENTATION_URL="https://wiki.almalinux.org/"
BUG_REPORT_URL="https://bugs.almalinux.org/"
ALMALINUX_MANTISBT_PROJECT="AlmaLinux-9"
ALMALINUX_MANTISBT_PROJECT_VERSION="9.6"
REDHAT_SUPPORT_PRODUCT="AlmaLinux"
REDHAT_SUPPORT_PRODUCT_VERSION="9.6"
SUPPORT_END=2032-06-01
OS: Rocky Linux 8
With direct build "dovecot".
I'm not sure if "build all" cause that issued or not.
Gonna try tonight if the server is not that busy, everything is running now with the old version.
OS Version =
NAME="AlmaLinux"
ID="almalinux"
VERSION_ID="9.6"
ANSI_COLOR="0;34"
Could you check if you have such packages installed on your server ?
rpm -qa | grep -i compat-lua
compat-lua-libs-5.1.5-20.el9.x86_64
compat-lua-devel-5.1.5-20.el9.x86_64
compat-lua-5.1.5-20.el9.x86_64
Please try to remove this package:
then try to build Dovecot once again.
That did the job thanks:
2025/11/12 16:52:12 info executing task task=action=rewrite&value=mail_sni
2025/11/12 16:52:12 info finished task duration=587.386012ms task=action=rewrite&value=mail_sni
inactive
Enabling dovecot in systemd...
Restarting dovecot.
[root@web01 dovecot]#
