DirectAdmin 1.689
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.689.
DirectAdmin 1.689
First of all, thank you for adding the CSF/LFD change to the DA version changelog.
It's about LF_INTEGRITY and PT_LIMIT.
This sounds a little bit confusing to me:
New DirectAdmin installations will use new default values. Configuration in existing servers will be updated with this DirectAdmin update.
These features are still functional and can be manually enabled. Once enabled manually, the configuration will not be disabled with the upcoming DirectAdmin or CSF updates.
So first line. Configuration in existing servers will be updated with this Directadmin update. Am I correct in the assumption that you mean existing servers which do not have made changes to csf.conf?
And for line 2. Once enabled manually, is the check done on a change of csf.conf or is the check purely done on these settings?
Because at this moment, we made some custom settings in csf.conf and we did not touch these settings as we use them at the moment, or at least using the PT_LIMIT regularly.
So if the check is done against the setting, then we know that we have to set it back as we never changed this one until now manually.
If the check is done against a yes or no manually changed csf.conf (no matter which setting) then it would be kept as is, if I understand correctly.
Hi all,
Afther updating is the imap server not working, is there something changed? Exim is still running
No accces to e-mail with Roundcube also. (No connection with the Imap server)
SMTP server is also not working, it look like that the mail is been send, but i recieved them not on gmail.
SMTP is still working :)
Already server restart, service restart and everything look online
New threat: https://forum.directadmin.com/threads/no-connection-with-imap-server.81114/
Yes, DA 1.689 will change these configuration lines. The check is done against the setting. This means it will turn them off and if you like them to be turned on you will need to turn them on manually. However this checking and changing the csf.conf file will be done only once and never repeated (not repeated after DA update, not repeated after CSF upgrade, not repeated after CB re-configuring CSF).
Nice update, especially the ticket system redesign. However, two things immediately strike me:
1. The ticket system still concatenates lines (line breaks are not displayed), which is very disruptive for log files and signatures.
2. The string ‘All rules are active. Use the form below to disable specific rules if needed.’ in the WAF cannot be translated.
Has anyone noticed slower processing of the email queue after the latest update (whether DirectAdmin, Exim, or Dovecot)?
I’m using SMTP2GO as my smarthost, and ever since the update, the mail queue has been taking a long time to process.
Today, when WHMCS ran its cron job, more than 70 emails stayed in the queue for almost 30 minutes before being sent. Sometimes messages go out immediately, but other times the delay is significant.
AlmaLinux 9. I’ve only updated a single server so far, so I can’t say for sure whether the same issue is happening on the others.
OK, I see AlmaLinux is also affected. I found the same on AlmaLinux 8.10 (Cerulean Leopard).
If you see exim crashes grep backtrace /var/log/exim/mainlog -A 12 you will need to downgrade it, at least Exim developers offer a fix.
Directadmin might need to downgrade Exim too
Maybe not all AlmaLinux versions or installations? I've got Alma 9 and do not have any stackdump lines or crashes when issueing that command.
Not on any of our Alma 9 servers.
Only have like this (if any)
2025-11-14 18:08:58 backtrace
2025-11-14 18:08:58 ---
2025-11-14 18:08:58     /usr/sbin/exim(+0x58fb7) [0x562047b15fb7]
2025-11-14 18:08:58     /usr/sbin/exim(+0x591c4) [0x562047b161c4]
2025-11-14 18:08:58     /lib64/libc.so.6(+0x3ebf0) [0x7fa23d63ebf0]
2025-11-14 18:08:58     /lib64/libc.so.6(+0x15e291) [0x7fa23d75e291]
2025-11-14 18:08:58     /usr/sbin/exim(+0x76722) [0x562047b33722]
2025-11-14 18:08:58     /usr/sbin/exim(+0x5bac0) [0x562047b18ac0]
2025-11-14 18:08:58     /lib64/libc.so.6(+0x295d0) [0x7fa23d6295d0]
2025-11-14 18:08:58     /lib64/libc.so.6(__libc_start_main+0x80) [0x7fa23d629680]
2025-11-14 18:08:58     /usr/sbin/exim(+0x334e5) [0x562047af04e5]
Anyway, just reverted them back via the new update just to be sure.
You posted a backtrace,
Ah oke so if backtrace present than crash. So the stackdump line is not required. In that case only 2 of 4 servers had no issues because only 2 server I had no backtrace.
Luckily I used the update, everything is running 4.98.2 now. I only see now from yesterday before I updated. Things look quiet now.
Thank you.
