DirectAdmin 1.691
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.691.
DirectAdmin 1.691
After running an update to DirectAdmin 1.691 in custombuild I get the following message:
Jailshell missing, update to 0.14 is available.
I do not use Jailshell or bubblewrap because my servers run CloudLinux with CageFS enabled for user isolation.
Is it necessary to install or update Jailshell in this case ?
@matkra, yes please install the script.
On CloudLinux systems the jailshell script will not be used for users with SSH access (unless manually enabled). However, we want to make sure jailshell script is available on all the DA servers.
Thank you, but when will the IPv6 validation on the multiserver page be fixed? Although it's accessible to do, It's getting to be a pain now having to edit the cluster.conf file to add an IPv6 server and then go back to DA panel to create the password hash. I've mentioned this a few times on here.
For reference, It broke when you released 1.686 as it worked fine in 1.685
Cheers 😊
I receive the following error by updating Apache in combination with ModSecurity:
httpd: Syntax error on line 51 of /etc/httpd/conf/httpd.conf: Syntax error on line 3 of /etc/httpd/conf/extra/httpd-modsecurity-enable.conf: Syntax error on line 1 of /etc/httpd/conf/extra/httpd-modsecurity.conf: Cannot load /usr/local/lib/libxml2.so into server: /usr/local/lib/libxml2.so: cannot open shared object file: No such file or directory
I can fix it by commenting the first row in /etc/httpd/conf/extra/httpd-modsecurity.conf with the text "#LoadFile /usr/local/lib/libxml2.so".
But after building ModSecurity or Apache, the problem is back.
  • Like
Reactions: ViT
@toktokcity I do not see "libxml2.so" record anywhere in the default DA configuration:
[root@server2 ~]# grep -R libxml2.so /usr/local/directadmin/ 2>/dev/null
[root@server2 ~]#
In Apache configuration some records are present, but they are commented out:
[root@server2 ~]# grep -R libxml2.so /etc/ 2>/dev/null
/etc/httpd/conf/original/extra/proxy-html.conf:# LoadFile       /usr/lib/libxml2.so
/etc/httpd/conf/extra/proxy-html.conf:# LoadFile        /usr/lib/libxml2.so
[root@server2 ~]#
I am using OWASP ModSecurity RuleSet and no similar problems.
Recommend checking if you do not have any customization related to Apache.
After the update, when I try to scroll through the ModSecurity 'Full audit log', the top lines keep disappearing, making it difficult to view the list properly:
  • Like
Reactions: ViT
I ran into this issue as well. I applied the same fix.
This is on a Debian 12 machine. I notice my AlmaLinux machine has a different path to libxml2.so (in /usr/lib not /usr/local/lib) and that path _exists_.
No, you don’t need to install or update Jailshell if you’re using CloudLinux with CageFS.
DirectAdmin is just reporting that Jailshell isn’t installed and that an update exists. Since CageFS already provides user isolation at the OS level, Jailshell (and bubblewrap) aren’t needed in this setup.
A lot of CloudLinux servers run without Jailshell, and this message doesn’t affect anything unless you actually plan to use it. You can safely ignore the warning.
It’s more that DA decided to always install the bwrap binary. Its size is basically negligible, and it’s not enabled by default on a CL system.
This gives admins the option to enable or disable it for testing without having to build anything, even on a CL system - the component is always there.
I have the same problem as you after updating to the new release.
I am using COMODO ModSecurity RuleSet.
Anyone seeing problem with multi server setup?
When it's enabled, creating a new user is looped never ending. The domain is not created in the remote DNS servers. The new user is not showed in the user list in DA of the source server. I needed to disable the multi server setup for creating a new user. After that, enabling the feature again, there is no problem with transferring dns records between the source and the remote servers. All servers running DA 1.691 on Almalinux 9, there was no problem before.
@ViT Please let us know what the results you get by running these commands:
and this one
da build list_removals
and this one
@romans
/usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-modsecurity.conf:LoadFile /usr/lib64/libxml2.so
Its original path was LoadFile /usr/local/lib/libxml2.so, but the file does not exist. This configuration previously worked fine with Apache versions earlier than 2.4.65.
It seems that the new Apache 2.4.66 update no longer accepts non-existent file paths.
I changed it to LoadFile /usr/lib64/libxml2.so, and it is working normally again.
# da build list_removals
If you want to remove all the suggested programs above, run: da build remove_items
it is a custom file, you might compare it with the original one from
/usr/local/directadmin/custombuild/configure/ap2/conf/extra/httpd-modsecurity.conf and delete the custom version if it does not meet your needs any longer
user login - menu databases - manage db expot as GZ and export as SQL - customers get "network error"
@Migratecpanel we are unable to reproduce the problem on our test servers. Please check the server error log and open a support ticket. Thanks.
