Spam Filters at Global Level
For white- black-listing of email addresses, domains, IPs you can use the following files:
/etc/virtual/bad_sender_hosts
/etc/virtual/blacklist_domains
/etc/virtual/blacklist_senders
/etc/virtual/whitelist_domains
/etc/virtual/whitelist_from
/etc/virtual/whitelist_hosts
/etc/virtual/whitelist_hosts_ip
/etc/virtual/whitelist_senders
For IF/ELSE filtering you can use /etc/system_filter.exim (the file /etc/system_filter.exim should never be edited in place, you will need to use directadmin native way to customize files)/
