Acces php files from multiple users
glenndavidson
Hi All,
i hope you guys can help me out. I have a shop/crm system build on user A. I add user b, user c etc to acces the source/php files with a custom httpd_conf with the following code (example)
|*if SUB="instore"|
|?SDOCROOT=/home/dauser/domains/domain.nl/public_html/instore|
|?USER=dauser|
|?GROUP=dauser|
|*endif|
Till today it worked, now i ran an update and i get on the page: File not found. error. Does someone have any idee that i can make it work again.
@glenndavidson Please provide more details what exactly you updated: DA ? Apache ? PHP ? Something else ?
Also put here the version you have now after update.
As option for the tests, try to downgrade to the previous version the software which you updated and test again if your SHOP started working fine.
I updated apache, to version 2.4.66. I downgraded it to 2.4.55 but i makes no difference. I think i have something to do with php-fpm and group right. Because i see a socket with dauser - apache
