Is this problem fixed in 1.692?I receive the following error by updating Apache in combination with ModSecurity:
httpd: Syntax error on line 51 of /etc/httpd/conf/httpd.conf: Syntax error on line 3 of /etc/httpd/conf/extra/httpd-modsecurity-enable.conf: Syntax error on line 1 of /etc/httpd/conf/extra/httpd-modsecurity.conf: Cannot load /usr/local/lib/libxml2.so into server: /usr/local/lib/libxml2.so: cannot open shared object file: No such file or directory
I can fix it by commenting the first row in /etc/httpd/conf/extra/httpd-modsecurity.conf with the text "#LoadFile /usr/local/lib/libxml2.so".
But after building ModSecurity or Apache, the problem is back.
It was most likely caused by custom configuration, check for custom files in /usr/local/directadmin/custombuild/custom.Is this problem fixed in 1.692?
This is the apache config file running atm:It was most likely caused by custom configuration, check for custom files in /usr/local/directadmin/custombuild/custom.
#!/bin/sh
"./configure" \
"--enable-systemd" \
"--prefix=/etc/httpd" \
"--exec-prefix=/etc/httpd" \
"--bindir=/usr/bin" \
"--sbindir=/usr/sbin" \
"--sysconfdir=/etc/httpd/conf" \
"--enable-so" \
"--enable-dav" \
"--enable-dav-fs" \
"--enable-dav-lock" \
"--enable-suexec" \
"--enable-deflate" \
"--enable-unique-id" \
"--enable-cgi" \
"--disable-cgid" \
"--enable-mods-static=most" \
"--enable-mpms-shared=all" \
"--with-suexec-caller=apache" \
"--with-suexec-docroot=/" \
"--with-suexec-gidmin=100" \
"--with-suexec-logfile=/var/log/httpd/suexec_log" \
"--with-suexec-uidmin=100" \
"--with-suexec-userdir=public_html" \
"--with-suexec-bin=/usr/sbin/suexec" \
"--with-included-apr" \
"--includedir=/usr/include/apache" \
"--libexecdir=/usr/lib/apache" \
"--libdir=/usr/lib/apache" \
"--mandir=/usr/share/man" \
"--datadir=/var/www" \
"--localstatedir=/var" \
"--enable-logio" \
"--enable-ssl" \
"--enable-rewrite" \
"--enable-http2" \
"--enable-proxy" \
"--enable-expires" \
"--enable-reqtimeout" \
"--with-ssl=/usr" \
"--disable-md" \
"--enable-headers"
Code:#!/bin/sh "./configure" \ "--enable-systemd" \ "--prefix=/etc/httpd" \ "--exec-prefix=/etc/httpd" \ "--bindir=/usr/bin" \ "--sbindir=/usr/sbin" \ "--sysconfdir=/etc/httpd/conf" \ "--enable-so" \ "--enable-dav" \ "--enable-dav-fs" \ "--enable-dav-lock" \ "--enable-suexec" \ "--enable-deflate" \ "--enable-unique-id" \ "--enable-cgi" \ "--disable-cgid" \ "--enable-mods-static=most" \ "--enable-mpms-shared=all" \ "--with-suexec-caller=apache" \ "--with-suexec-docroot=/" \ "--with-suexec-gidmin=100" \ "--with-suexec-logfile=/var/log/httpd/suexec_log" \ "--with-suexec-uidmin=100" \ "--with-suexec-userdir=public_html" \ "--with-suexec-bin=/usr/sbin/suexec" \ "--with-included-apr" \ "--includedir=/usr/include/apache" \ "--libexecdir=/usr/lib/apache" \ "--libdir=/usr/lib/apache" \ "--mandir=/usr/share/man" \ "--datadir=/var/www" \ "--localstatedir=/var" \ "--enable-logio" \ "--enable-ssl" \ "--enable-rewrite" \ "--enable-http2" \ "--enable-proxy" \ "--enable-expires" \ "--enable-reqtimeout" \ "--with-ssl=/usr" \ "--disable-md" \ "--enable-headers"
/usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-modsecurity.conf
/usr/local/directadmin/custombuild/configure/ap2/conf/extra/httpd-modsecurity.conf
Hi,@Marwen, please open a support ticket. There should be no changes in how custom template files between the 1.690 and 1.691 versions.
Thanks!You are looking at wrong file.
Check your custom file located here:
and compare with the file that directadmin uses:Code:/usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-modsecurity.conf
Code:/usr/local/directadmin/custombuild/configure/ap2/conf/extra/httpd-modsecurity.conf
You'll notice that DA file does not have any libxml2.so load line, and some other slight changes.
Consider removing the custom file to fall back to the default DA modsecurity file.
There are more differences in that file, like inclusion for the disabled rules, the ifmodule section.Thanks!
I did commented the first row in /usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-modsecurity.conf with the text "#LoadFile /usr/local/lib/libxml2.so" and now it works again!
After the update, when I try to scroll through the ModSecurity 'Full audit log', the top lines keep disappearing, making it difficult to view the list properly:
"Full Audit Log" should be working fine in DA version 1.692 (current release). Please try to update to that version and check if it helps for your case.Is there already a solution for this? Thx!
Thanks for your quick response! I have the same issue on a server running v1.692."Full Audit Log" should be working fine in DA version 1.692 (current release). Please try to update to that version and check if it helps for your case.
Issue is still here. I have a long list (30) of excluded rules above the audit log. Maybe this has something to do with it?so, rewrite_confs then?
