Email messages being duplicated after last DirectAdmin update
EdsonGomes
Problem started after the last update a couple days ago (possibly related with Exim update, but I'm speculating).
Messages received are being duplicated at the inbox, but only in the default email account.
For example, if I have a domain mysampledomain.com in my server, with 3 email accounts:
[email protected] (DEFAULT account, auto-generated, "mysampledo" is the login)
[email protected]
[email protected]
When I send test messages to all 3 accounts from and outside email (GMail, for example), the message sent to the first email is duplicated at the inbox with some additional headers ("Return-Path", "Delivered-To" and "Received") right at the top - all the rest stays exactly the same.
Already tested in 2 different servers with the same configuration, same problem, always and only in the default account.
Already tried to remove all my personalized exim filters to see if the problem was there and, nop, same results.
Can someone point me to a solution which doesn't involve "stop using the default email account", IF possible?
Thanks in advance.
Yes, I do have the same issue. I opened a ticket about this incident.
Later Edit,
Site redirection does it have a similar bug? I've made some changes yesterday, and today when I logged in those was removed but still active.
Thank you for that. Would be possible for me to watch this ticket using a link of any kind?
I'm almost having to reset my domains from scratch with new usernames to avoid using the default email account (since it's not possible to change the domain login or the default email account).
Later Edit,
I didn't notice any bug related with site redirection, but to be honest, all redirections that I do, I use a default index.php script to do it (I have trust issues with any other type of redirections...).
This may be a private message but all I can say, they told me that was fixed on the ALPHA version 1.694. So you have to migrate to this for now. Otherwise maybe a downgrade if you don't want to use ALPHA base? Don't take my advice, you better open a ticket I think.
Thanks.
Bash:
--- exi    2026-01-26 15:54:41.600030128 +0200
+++ exi.orig    2026-01-26 15:59:51.383252754 +0200
@@ -1,4 +1,4 @@
-# SpamBlockerTechnology* powered exim.conf, Version 4.5.61
+# SpamBlockerTechnology* powered exim.conf, Version 4.5.62
 # Exim configuration file for DirectAdmin
 # *SpamBlockerTechnology is a Trademark of NoBaloney Internet Services:
@@ -692,7 +692,14 @@
   pipe_transport = virtual_address_pipe
   retry_use_local_part
   # pass a copy of the email to the next 'virtual_mailbox' router if this address is also a mailbox
-  unseen = ${if exists{/etc/virtual/${domain_data}/passwd}{${lookup{$local_part}lsearch{/etc/virtual/${domain_data}/passwd}{yes}{no}}}}
+  unseen = ${if and {        \
+               {exists{/etc/virtual/${domain_data}/passwd}}                                        \
+               {bool {${lookup {$local_part} lsearch {/etc/virtual/${domain_data}/passwd} {yes}}}} \
+               {!eq        \
+                   {${lookup {$local_part} lsearch {/etc/virtual/$domain_data/aliases}}}           \
+                   {$local_part}        \
+           }{yes}{no}}
   .include_if_exists /etc/exim/local_part_suffix.conf
 virtual_mailbox:
If it has been solved in the version 1.694, I can endure the problem until the next DirectAdmin update (provably next month). I really wouldn't like to downgrade or use an alpha version in my production servers. Thanks for this piece of information.
About your follow reply... I don't know if I got it.
It's your own way to solve the problem until the next DA update?
DA normally kick out hotfixes quite quickly for critical bugs like this so i'm surprised they haven't done so so far. I do have to say though they are very good and prompt at releasing updates. These are usually between 1 and 4 weeks inbetween so if you hold on, 1.684 will be released in less than a few weeks i'll bet.
