MySQL server down
dorucrisan
Bucharest / Romania
My SQL server is down for unkown reason and I cannot install it.
Error message as below:
Any idea how can I solve that?
I cannot install Maria db from inside Custom Build as well using "build" command.
I don't know if you have data or not. This is what I would do. Rename /var/lib/mysql to /var/lib/mysqlOLD Uninstall the rpm first. Install mysql using Custombuild.
That's what I would do also. Installing anything from Custombuild nearly always guarantees it will work with DA and function properly. You can install from the web gui or via the 'da build xxxxxx' command if you prefer the terminal.
