Mail relay from on-premesis Exchange
cDGo
I have an external DNS in which mail per domain/user is forwarded to an on-premesis Exchange server.
The alma-linux 9.7 server is not handeling mail it self for any user.
The exchange server is sending out email through the ISP.
Now I want to use the webserver to become a mail relay for the exchange server instead of the ISP.
Still all incoming mail and mail from the webserver itself (webforms etc.) needs to be forwarded to the Exchange server.
Is that even possible?
I think so.
Theoretically, if you use DA as smarthost to the Exchange server then it will also send mail generated locally to the Exchange server. It's up to the Exchange server on how to handle these mails.
As for receiving mails, it's a question of putting the MX record to the ip of the exchange server and it will receive mails directly.
You might want to have a look at this:
Hello Richard,
Thanks (again) for answering my question(s).
I've come across that page in my serach before.
But I do not get what it should be setup like.
Because my guess is that the "Remote server hostname" should be smtp.domain.com which is the local server on which these settings are done?
I think this is ment for the situation when the domain.com server wants to send mail through a remote server like smtp.domain2.com
My DNS settings now:
mail A 300 EXCHANGE_IP
MX 300 10 mail.domain.com
For an additional 5 domains, this is set the same for each one of them.
MX 300 10 mail.domain2.com
etc.
All mail from these domains are now forwarded to the exchange server which is what's needed.
Now when I reply an email from within th exchange enviroment it goes through my ISP and then uses the Dkim of the ISP (KPN so not aligned to domain.com) and therefor the email goes straight into spam when sending to a hotmail.com address.
When I want to use the domain.com server as my actual sending server (dkim then is aligned) I've set up the smart-host in exchange to be domain.com.
But then I get a error server unreachable on sending/replying to an email.
This probably is, because the DNS reroutes the outgoing email back to the exchange IP
So I'm kinda stuck here on how to set it up correctly.
Ah oke sorry, then I misunderstood. I though you ment on premises but with another domain name.
What you in fact want is a kind of a double smarthost. I have no clue on how this should work.
You might be able to solve the issue by not using a DKIM on your own server, but only using SPF, and ofcourse include the KPN SPF system, hoewel that is probably not what you want.
I might tag @mxroute for you. He knows lots about mail systems so maybe he has an idea. There was another person but unfortunately I fogot his name.
I will follow this topic just out of curiosity if such construction is possible and how it should be constructed.
Hi Richard, thank you very much, let's hope there is more info to be shared on this.
On the smarthost, you can config using any domain/sub domain, just point the record to target IP server.
DKIM, you must config on exchange server like "x2", and leave "x" for your domain server.
With this, on the same domain, you can use both DKIM server.
Yes but in fact the second mailserver will be a smarthost for the ISP mailserver which is eventually really sending the mail outside to the internet, making it's own SPF/DKIM records. Which is causing the issue.
Yep, that's DNS issued. It required to adjust the SPF to allow exchange server and sync public DKIM key from exchange server as "x2" or other name.
That's how I adjust 2 Directadmin with same domain that allow to send the email from the both server.
If you can't sync DKIM public key from the exchange server to DNS record, then it's end here.
I might be one to something, but can only continue tomorrow.
As soon I have progress, i'll update this thread
Thank you both for now
After testing a while, I came up with 2 possibilities on solving it
1) As the exchange server was new, it could have been a low reputation issue.
2) It could have been a lazy testing "if it works" sending terrible emails (subject and content)
After installing (open source plugin) Configuration.DkimSigner I could add a DKIM to the exchange server's mail domains.
And sending from a second domain, it just worked out of the box.
So maybe the better composed subject/content did the trick, but most likely it was the adding of DKIM
