Node.js with Nginx Unit on DirectAdmin
NemamNadimak
So I am having troubles with this and I would appreciate if someone can shed me some light or provide tutorial how to run node.js app with Nginx unit.
I installed Direct Admin and enabled Nginx Unit.
I created user and I see Nginx unit icon. I took Hello world app from this man page.
After that I tried to follow rest of the steps, but after I create Application with the following settings
Working directory: /home/user/domains/example.com/public_html/myapp
Script: app.js
it proceeds to create a route.
Once on the screen, there is no any template available for Node.js so I assume I can skip it
in the rest of the fields whatever paths and values I enter I get
"Reconfiguration Error: Value doesn't exist."
What I am not seeing?
Script: app.js
having the same issue, do u find a solution ?
I still having the same issue too, did you find a solution at this time?
Faced the same error, and the following command helped in my case:
/usr/local/directadmin/custombuild/build rewrite_confs
You might try the same.
I'm experiencing the same problem; no matter what I do, I get a 503 error... A simple single-file app.js file, without a backend, prints "Hello World" and it works flawlessly.... But when I try to run an application with a backend, I can't; I constantly get problems, constantly meaningless 503 errors.
Isn't there a video showing how to develop and publish a seamless backend application for Node.Express using a direct admin panel interface?
The simple Hello-World application would be like the following:
JavaScript:
const http = require('http');
const port = process.env.PORT || 3000;
http.createServer(function(request, response) {
  response.writeHead(200, {'Content-Type': 'text/plain'});
  response.end("Hello, World! From Node.JS (2)\n");
}).listen(port);
console.log(`App is running... (port: ${port})`);
It's a working example tested be me.
