Mailbox quota limit does not get updated on change
Richard G
Maastricht
We're using Enhanced skin still for a various customers.
Since I get postmaster mail. I got mail from the mailor-daemon of mail which got returned because of "quata full" of a customer.
LMTP error after end of data: 552 5.2.2 <[email protected]> Quota exceeded (mailbox for user is full)
So Iogged in as the user and indeed the 50 MB default quota was on, and on request of the user I set it to 0 which is unlimited. Doublechecked and it's unlmited now.
However, today I got another mail send to that mailbox and again the same notice about quota arrived.
Doublechecked, no quota limit for the e-mail for the user, so mail should not be refused.
I have to "up" this as it is still happening. For some reason it's not fixed by nightly tallys. Seems a bug to me.
Is there any way to maybe reset this counter? @zEitEr any clue?
I will try to set it higher and see what it does, but it should be just unlimited when set to 0.
Thank you,.
This is a way to test things, it will show if the issue persists or not.
Whether or not you get an alert with updated quota, then you can try again with the unlimited.
I guest, you still using Enhance skin. In now day, "0" doesn't meaning "unlimited", try switch to Evolution skin and re-set unlimited again.
So I don't know how DA manage other package item, so just try it.
It's al the same, doesn't matter if you use Enhanced or Evo. Evo just has certain extra options but the rest works the same.
After Zeiters reply I set the limit to 500 MB and now I wait what happens. As soon as it's over the 50 MB content (which it has now) then I set it back to 0 and see if it's a bug or if it's working correctly then.
