BFM using csf.deny and not iptables directly
SEO Guru
I am wondering why Brute Force Monitor is adding entries in csf.deny instead of using csf command to ban through iptables directly. Wouldnt this be a more neat integration?
The fact, they still use the command, but only use the perm block instead of temp block when setting BFM to ban on the timing like 1hr.
There is a choice. By default as Ohm J stated, the perm block is used.
However, you can create custom files if you want to use temporary blocks.
This requires the brute_force_notice_ip.sh and block_ip.sh in the /usr/local/directadmin/scripts/custom directory.
This will however overrule the build in section. I can give you the contents if you're interested. I also use them as I also want to decide on what to give perm blocks and how long temp blocks should be active.
