DirectAdmin 1.696
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.696.
DirectAdmin 1.696
What's happend if we using cloudflare as DNS Manager and don't add any "NS" record into the cloudflare ?
I assume the question is about the new check we perform before issuing the wildcard certificates. It could be one of the following situations:
  • Use CF for DNS and issue non-wildcard certificates. The NS records does not matter, the NS check will not be performed.
  • Use CF for DNS and issue wildcard certificates and have CF configured as DNS provider for the ACME challenge. The NS records does not matter, the NS check will not be performed.
  • Use CF for DNS and issue wildcard certificates and have no custom DNS provider configuration for ACME DNS challenge. The NS records will be checked and DA will refuse to issue wildcard cert. But even if DA would not refuse it at the early stage, it would still fail to issue the wildcard certificate. This is because without custom DNS provider config DA would try adding DNS challenge records to the domain zone (which it does not control) and the challenge would fail.
If you have some other non-standard configuration and the NS check causes you problems - let us know. The purpose of this check is NOT to limit users ability to issue wilcard certs, but to fail early in situations when we know it is guaranteed to fail if we continue.
I’m noticing some strange behavior: when you click on an admin user, you’re redirected to the reseller. Because I want to remove an IPv6 address from an admin user, I’m currently unable to do so.
It can be related to these changes:
when the TABs to switch between USER and RESELLER were replaced with buttons.
When I search and select a user via the top search bar (Ctrl+K), I get to `/evo/admin/users/{USER}/view/domains` and was always able to delete it there. Right now I can't select the user and Delete it. I have to do another search on the "My Users" or "Show All Users" page and it takes more time.
When you want to scroll all the way down in Email Tracking to see the last record, the scroll kind of gets stuck or moves up and down. On the desktop, this is not pleasant but not disturbing; on mobile, it actually doesn't work at all, you can barely see the last record of the Email Tracking function.
How large are your /var/log/exim/mainlog* files ? Could you provide the results of this command:
ls -lah /var/log/exim/mainlog*
