zEitEr
Super Moderator
You might open a ticket with DA support and let them fix it for you.
Hi, sorry for the late reply - alerting/notifications don't seem to work here.Hello,
Is there any chance you used the domaingvsteyvo.beas a hostname? Do you have subdomains created in the domaingvsteyvo.beunder other user accounts?
How do you request a new certificate? Do you use command line or directadmin interface? Do you renew an existing certificate? Or request a new one?
In anyway you might try and remove *cert, *cacert, *key files from the directory /usr/local/directadmin/data/users/gvsteyvo/domains/ and try again.
Looking at that, you need to give a REAL email address. They never email you (i've never received any emails). Try again with a real email and see if you still get the same output above2026/03/17 08:38:28 [INFO] acme: Registering account for [email protected]
2026/03/17 08:38:29 Could not complete registration
acme: error: 400 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-acct :: urn:ietfarams:acme:error:invalidContact :: Error validating contact(s) :: contact email has forbidden domain "example.com"
Thanks in advance!
