/usr/local/directadmin/scripts/custom/letsencrypt.sh
Driesp
Belgium
Hello all
It seems like the letsencrypt.sh script is now bundled in the DirectAdmin binary. Or something else is happening.
I can remove the letsencrypt.sh file in /usr/local/directadmin/scripts or /usr/local/directadmin/scripts/custom and DirectAdmin still processes certificates fine.
I changed the letsencrypt.sh script a long time ago, but I noticed my changes are not honored anymore.
I now tried using the pre hook, but that did not work either. Or maybe I am doing something wrong.
I used the file /usr/local/directadmin/scripts/custom/letsencrypt_pre.sh with the following contents to change the keysize, but that did not work either.
#!/bin/sh
keysize="ec256"
I used this feature:
I want to override to ec256 always regardless the selected keysize.
I hope to find an alternative way to override the keysize.
Thank you in advance
Kind regards
Dries
Hello Dries,
The feature does not work that way. You cannot change the value of environmental variables in the Hook script. The Environmental variables can be used in read-only mode.
A custom version of the script should be placed in /usr/local/directadmin/scripts/custom/letsencrypt.sh
Related: https://docs.directadmin.com/changelog/version-1.51.0.html#custombuild-to-manage-letsencrypt-sh
Hello Alex
Thank you for your quick reply.
I have been patching a copy of letsencrypt.sh into /usr/local/directadmin/scripts/custom/letsencrypt.sh, but it seems like DA does not call this script anymore when creating or renewing certificates.
Kr
Dries
@Driesp, yes we are migrating the letsencrypt.sh script logic into the main DirectAdmin service.
Could you please share with us some more details or use cases for why you want to prevent other certificate key sizes from being used? We would prefer to allow server administrators to configure the DA behaviour with the configuration options instead of script customisations.
confirmed. The script /usr/local/directadmin/scripts/custom/letsencrypt.sh is no longer used:
Bash:
# cat /usr/local/directadmin/scripts/custom/letsencrypt.sh
#!/bin/bash
echo Testing...
exit 1;
Hello. We change the TTL values for DNS records when issuing wildcart certificates. Therefore, we also use our own letsencrypt.sh script. If this script no longer works, we would like to see this setting in the control panel itself.
Hi fln
Thank you for the prompt reply.
I would like to use the ec256 keysize for all certificates, I am convinced any other keysize has no positive benefit for our clients.
Keys are also cycled every certificate renewal, I don't think a bigger size is beneficiary (in 2026).
Kind regards
Dries
Thanks, @Driesp, indeed you are right, there is little value in getting larger EC keys. However, I am not really sure if it is really worth actively blocking the key type selector for the users. Most of them are fine with the default size and do not really care. And if they do change the key type there is little harm in doing that.
@splby what TTL values are you using? Are there any problems with the default value? The letsencrypt.sh uses 5 second TTL by default for the DNS challenge record. This script is still used by the lego CLI tool for adding and removing DNS challenge records. However main DA service now instructs lego to always use scripts/letsencrypt.sh, even if the scripts/custom/letsencrypt.sh exists .
Thank you fln. I understand why DirectAdmin gives the end user the possibility to change the keysize. And it is a positive thing, DirectAdmin is very customizable.
However, most of the end users don't know what they are doing, and they don't care, indeed.
Using smaller key sizes also leads to faster TLS handshakes.
And currently EC384 is highlighted as the standard when requesting a new certificate in DirectAdmin.
Kr
Dries
  • Like
Reactions: fln
Agree, there have end user might thinking like, "let's pick small keysize for fastest website.", but hosting provider have their own ways to adjust the real default protection, even mostly ec256 is secure enought and don't want the user change the thing.
Example: hacker can capture the current https request and try decode with AI in the future using super computer.
We use TTL 100. Our backbone provider either blocks it or has some issues with TTL records below 60. Currently, we change the TTL value directly in the script after each update.
  • Like
Reactions: fln
Hi there,
Hope you're doing well.
I would like to inquire if there is a possibility to place our own logic of certificate issuance.
I meant the infrastructure that I'm using is having trouble connecting letsencrypt (network issues). So, it can't access the internet or even letsencrypt to complete the process.
Therefore, I would like to know any kind of procedure that can lead us to a new milestone.
I need to ensure that my users press the directadmin or even if the admin press the Manual Trigger, my script runs and use my procedure to issue the certificate.
Best
@splby, the default TTL value for DNS challenge records is bumped from 5 seconds to 60 seconds in the default letsencrypt.sh script.
@mr.sharifi, the DirectAdmin still relies on lego CLI tool to issue the certificates. If you want to control the logic that connects to Let's Encrypt servers, the best way forward would be replacing /usr/local/bin/lego with a custom script.
Thank you, maybe I can also write a wrapper script around lego to change the default keysize. I will have to look into this.
Kr
Dries
Thank you very much for your response.
This one perfectly works for me.
However, I need to know what kind of response my script should return to prevent an error of "Couldn't execute your request."?
@fln Is it possible to make TTL a configurable parameter? TTL 60 doesn't work for us, but higher does, so we need 61 or higher.
It would be easy to make it configurable, however there is little value in keeping the TTL low. The ACME servers will perform a fresh DNS lookup without cache anyway. I think it would be better to just update it to a value that would work for everyone without adding more configuration knobs.
In the next DA release the default TTL will be raised from 60 to 120 seconds.
Thank you @fln,
However, we have realized the corresponding path, /usr/local/bin/lego, is reverted to the original bin file.
Is there any feasible solution to prevent that action or make it permanent?
(In fact, using chattr or even a cron job is not possible. Mainly, due to building problems.)
