CSF future on DirectAdmin — Where do we stand 6 months after the shutdown?
If I had my druthers, I would prefer that a third party develop a CSF replacement that works with both DirectAdmin and cPanel (as well as panel-less hosting).
That was the nice thing about CSF is that the syntax was the same for cPanel and DirectAdmin (presumably other control panels that it worked with). The fear I have with a control panel backed CSF replacement is that it's only going to work for that control panel. DirectAdmin has no reason to insure their implementation of CSF works on cPanel servers. So then you wind up with a CSF for DirectAdmin and a CSF for cPanel.
The ONE thing I would encourage, for anyone that's forking off of CSF... call your product something else, don't reuse the CSF name. Because we're going to get to the point of "CSF over here isn't the same as CSF over there."
My hope on this matter is, that somebody of the csf forks people will modify CSF for nftables and put it out as open source. I guess latest then, DA stuff will jump on the new code.
CSF is open source and must remain that way so I don't worry about that part. I did see some people forking CSF and working on it.
As much as I also would like some situation as to where CSF could be used like it was before, so for mutiple panels, I also would like the same security and stability.
There is not really a group of programmers picking up the project, and next to that both cPanel and DA created their own fork, and there is already some slight difference if I'm not mistaken. Not really something which changes basic functionality but still.
If somebody would take over then it should be trustworthy and expected to be stable for some years to come or indeed start a new project under a new name (indeed better).
DirectAdmin doesn't actually do anything with CSF; there are a few minor adjustments, but all the old settings and publisher years of wtw limited are still there in the footer.
Not keeping up with development does not seem sustainable.
I don't agree with both. One does not need to develop for develop sake. You have to go with the future but if things are working fine and there is no developping required, then what should one develop?
Good examples PINS (offline password program from 2003), better example FlashFXP (still way better then developped Filezilla).
Same as at CP. At this moment they don't do anything with it, but it's not said they won't be doing things. It would however be great if they would give us notice if they have some idea's about it, or if they are just waiting to see how other forks develop.
Because a real nftables implementation would be great, maybe that can forgive the los of ipset a bit.
But usually software needs occasional bug fixes and security updates. My image editor is from 1998. It works just fine for my needs. But it's also not assessable from the internet.
started as a internal joke last August (30/08/25) "hey, csf is shutting down, I'll built my own", and it runs perfectly fine in ~30 production servers.
Pure nft - no iptables, wrappers or ipset, pure go (no cgo), single binary, no perl/bash scripts or hacks or crons, internal tickers, and went down from "something like csf" to a complete L3-L7 system (Challenge server, interceptor with lua scripts for WAF/Challenging/Throttling), mysql governor (watcher/enforcer), and so on. Still, it's not "plug n play" more of "plug n pray". lot's of config files, no UI for installation of configuration.
Anyone feeling brave enough is welcome to give it a shot - https://github.com/chrismfz/cfm (Not for the faint of heart).
I produce rpm/deb packages. Or someone can compile the go code.
As was the case with CSF/LFD in the beginning, so that should not be a big issue. :)
But it's nice to hear you build something which works great for you. I probably won't test it on the production servers, but will have a look at it when Github is loading a bit faster then it's doing right now.
