DirectAdmin 1.700
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.700.
DirectAdmin 1.700
Isolated PHP-FPM mode for legacy DirectAdmin codebase​
Support for running fully isolated user owned PHP-FPM instances in backported to the legacy DirectAdmin code base.
Nice :)
After updating to DirectAdmin 1.700, the “System Information” option has disappeared from the admin panel.
Even when trying to access it directly via “/evo/admin/system-info”, it returns a 404 (Page Not Found) error.
Additionally, the issue with untranslated page titles that I reported on the forum for version 1.698 still persists and has not been resolved.
(https://forum.directadmin.com/threads/directadmin-1-698.82115/post-399812)
Please check release notes for DA version 1.700:
Thank you for the response, @romans
I had seen that information, but I assumed it was a bug.
Previously, it was possible to check disk usage percentages, but that has been removed. Now, not even administrators can view this information anymore.
So, if we want to check whether a server is running low on disk space, do we now have to rely on the terminal to verify it?
Thanks for the info! Rely on this heavily and don't wish to have to switch to User mode each time, is there a way to add another System Information link where it was originally under Admin? Cheers.
We noticed that exim.conf was updated from 4.5.62 to 4.5.63, but this is not listed in the changelog. Does the change only refer to removing the email size requirement for spam checking?
We are investigating a possible old bug in the sent message count; apparently, exim.pl is counting multiple retries of certain message types, resulting in inaccurate counts. This new update doesn't bring anything related to counting, correct?
@unihostbrasil, the Exim configuration version have changed because Easy Spam Fighter (ESF) files have changed. ESF is now part of exim config (it can still be enabled or disabled). There is no separate ESF version, any time there is change in ESF config, the Exim config version will be bumped.
In that case....What about the strings.conf.custom and variables.conf.custom file, will these still work? Or do we need another method now to adjust certain values we have customized in there?
@Richard G, everything stays the same and works the same.
The only difference is that ESF used to have it's own version number and exim.conf used to have it's own version number. Now they both share the same version number. It makes it impossible to have old exim.conf and new ESF files. Or other way around, update the ESF to the latest but continue using old exim.conf config.
Even if you're on Admin or Reseller, just press Cmd + J (Ctrl for Win) and type info and hit enter. Believe me it is faster than locating and clicking :) DirectAdmin is perfect with these shortcuts.
I have this error after update:
May 04 09:12:11 XXX systemd[1]: Started Exim Mail Transport Agent.
May 04 09:12:11 XXX exim[1345781]: 2026-05-04 09:12:11 Exim configuration error:
May 04 09:12:11 XXX exim[1345781]: can't redefine an undefined macro "EASY_SPAMASSASSIN_MAX_SIZE"
May 04 09:12:11 XXX systemd[1]: exim.service: Main process exited, code=exited, status=1/FAILURE
May 04 09:12:11 XXX systemd[1]: exim.service: Failed with result 'exit-code'.
Yeah, you likely have it defined in
/etc/exim.easy_spam_fighter/variables.conf.custom
Just remove the line as the variable doesn't exist anymore (or remove the file if that was the only line there).
  • Like
Reactions: fln
We will be releasing an automatic fix for removing the old variable from the /etc/exim.easy_spam_fighter/variables.conf.custom.
i dont see in custom build option for apache 2.4.67 only in next version with ?? on the date, any eta when it be released cause latest cve?
The DA version 1.701 is released. It comes with new apache and exim. Version 1.700 also got latest apache and exim versions.
@fln I know that I am be able to create custom entry in menu. Btw good solution was "System Information" on admin page.
