Wrong usage of limit
inomi13
I noticed that one of my user has wrong disk usage. I set limit 50GB and currently disk usage is 35GB, however directadmin shows usage on 51GB.
When I login via user and refresh usage or change limit quota of this account then da shows correct value but next day da shows a one more time wrong usage.
I checked the limit settings and disk usage by logging in via SSH. This an issue only one account.
du -sh home/username
35G /home/username
quota -u username
Filesystem blocks quota limit grace files quota limit grace
/dev/vda4 36323080 52428800 57671680 52515 0 0
it counts all data that owned by user on all partitions where quota monitored (maybe you have extracted backup of this user files in admin account), + it counts database usage, so check DB size too.
First of all what I did, was check all files in system which have owner that user.
I noticed one correlation, every single day backup of user accounts start at 12:00 midnight and tally cron function runs at the same time so probably here is an issue. I changed start backup to 12:30 AM and we will see tomorrow.
you can edit quota for user, from DA, like modify just any digit, save, revert - it will run quota update for this exact account immediately.
I know and I changed quota for user from DA and then disk usage shows correct value. As I told, an issue with wrong disk usage shows next day.
Depending on how you backup, a 35gb account can add a damn lot to those 35gb, for a little while. Well, 35gb might not be 'a little while'. If da calculates when the backup hasn't finished yet, it might see a lot more data in use. I guess... not sure if that's the case tho.
As I thought, problem which disk usage exist because in the same time start tally cron and runs backup.
In my option it is bug of da which should be improve.
It's not a bug, inconvenient maybe but It's more a server management thing. Or simply timing. You never know exactly how much space a backup is requiring and you only find out when ... there is not enough.
