- Aug 30, 2021
Yes another local privilege escalation vulnerability was recently publicly announced - dirtyfrag.io.
Mitigation does not require server reboot, only making sure kernel modules
Note: The esp4 and esp6 modules are used by IPSEC. If your server is using IPSEC unloading them will break the connections over IPSEC or unload operation will fail. Quick check to make sure modules are unloaded - command
esp4, esp6 and rxrpc are disabled.
: > /etc/modprobe.d/dirtyfrag.conf
echo 'install esp4 /bin/false' >> /etc/modprobe.d/dirtyfrag.conf
echo 'install esp6 /bin/false' >> /etc/modprobe.d/dirtyfrag.conf
echo 'install rxrpc /bin/false' >> /etc/modprobe.d/dirtyfrag.conf
rmmod esp4 esp6 rxrpc 2>/dev/null
lsmod | grep -F -e esp4 -e esp6 -e rxrpc should return no results.
