Solved Letsencrypt not renewing automatically on 1 account
Richard G
Maastricht
Has something changed on the LE renewal period?
Normally the certs were valid for 90 days and would be renewed after approx. 60 days.
Last time an SSL certificate of a customer was not renewed automatically so I had to do it manually. I do not have setup AutoSSL for this domain, but that should not be necessary.
Now I'm looking again and the cert is valid until May 30th and we are 2 weeks from that date, so it should have already been renewed way before this date.
Checking DA it says:
Let's Encrypt in use. Auto-renewal in 0 Days.
So one should expect that it would be renewed today, but I think it's already for a longer time 0 days.
Retries are also still good: Remaining Retries 17
So what could be going on here. Why is the renew not triggered begin this month as should be done normally?
I noticed I have a few doing this as well. I never dug deeper since I was debugging another error (stale SOA/NS records in local resolver cache).
Hi, the default value when certificates are renewed was changed almost a year ago, see 1.677 changelog. The current default value is 17 days before certificate's expiry time.
You can check the current value on your server:
# da config-get letsencrypt_renew_before_expiry_days
17
In your situation, it seems like certificate should be renewed within the next 24 hours.
If it does not renew, you can check the acme-lego output here:
cat /usr/local/directadmin/data/users/USERNAME/domains/acme_provider_cert_logs/DOMAIN.log
and/or run renewal manually and look for possible issues:
da taskq --debug=1 --run="action=rewrite&value=letsencrypt&domain=DOMAIN"
