Webalizer not able to show IP locations
logixwebsol
Hello Everyone
I have install the directpanel and Webalizer not showing the IP address and locations.
Please help me to solve it.
Is that still up to date? If yes, then it's incomplete, it states:
Also you need to set the proper permissions/ownerships for that file:
chown root:root /var/lib/webalizer
chmod 1777 /var/lib/webalizer
But this directory does not even exists so needs to be created first in that case.
enable reverse IP lookups in webalizer.conf
As this documentations says none of the things match. It old or useless documentation.
This also not worked.
None of the thing or solution matches.
Please suggest any other solution.
