php update failing
117434
Earlier today I updated some packages using update all that I had not yet done.
Then I had 4 updates that needed doing. PHP was the one I really wanted to do but update failed 3 times and closed. I then rebooted the entire server in the hopes that might solve the problem.
I realize this is not enough info so please tell me what I need to provide so that you might help. I now have the entire log on local machine.
Alma-Linux server running the 5/16/26 1.70xx version of DA.
What will you see if you run?
Bash:
da build list_removals
You might remove old libraries, in case they are shown by the first command.
Bash:
da build used_configs
You might review the custom/php/configure.php* files, if they are shown by the second command.
Other than that you might have dependencies issues and/or RAM, disk space related problems.
I just discovered that I don't know where to run either of those commands. I am guessing there is a command line option somewhere I never explored?
If this is the case, you'd better get someone to fix it for you. I won't guide you as well as anybody else on how to use SSH and run commands as "root".
If you still want to learn the basics, you might start with the following articles:
- https://docs.directadmin.com/operat...naging-with-ssh.html#managing-server-over-ssh
The removable items are also visible in the CustomBuild GUI. Server Management -> CustomBuild -> Remove. Example:
