Hello all.
I am running a Directadmin server with cloudlinux on Alma 10 since few months.
I almost have no problems until now.
My current mariadb version is:
mysql Ver 15.1 Distrib 10.11.15-MariaDB, for linux-systemd (x86_64) using readline 5.1
I just tried to update packages with dnf update and went into following conflict:
my dbgoverner version:
dbctl --version
version 1.2-143
my os info:
my kernel:
6.12.0-211.7.3.el10_2.x86_64
CloudLinux OS Shared
DirectAdmin,1.703
May be this is related to Cloudlinux OS update to 10.2, but how can I figure it out?
dnf update
Last metadata expiration check: 1:21:58 ago on Wed 03 Jun 2026 01:47:28 PM CEST.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
kernel x86_64 6.12.0-211.7.4.el10_2 baseos 1.6 M
kernel-core x86_64 6.12.0-211.7.4.el10_2 baseos 19 M
kernel-modules x86_64 6.12.0-211.7.4.el10_2 baseos 42 M
kernel-modules-core x86_64 6.12.0-211.7.4.el10_2 baseos 30 M
kernel-modules-extra x86_64 6.12.0-211.7.4.el10_2 baseos 3.0 M
Upgrading:
cl-MariaDB-meta x86_64 11.8.6-1.el10 cloudlinux-rollout-1 9.7 k
cl-MariaDB-meta-client x86_64 11.8.6-1.el10 cloudlinux-rollout-1 8.9 k
cl-MariaDB-meta-devel x86_64 11.8.6-1.el10 cloudlinux-rollout-1 8.2 k
cl-MariaDB1011 x86_64 10.11.17-1.el10 cloudlinux-rollout-1 7.8 M
cl-MariaDB1011-devel x86_64 10.11.17-1.el10 cloudlinux-rollout-1 8.0 M
cl-MariaDB1011-libs x86_64 10.11.17-1.el10 cloudlinux-rollout-1 188 k
cl-MariaDB1011-server x86_64 10.11.17-1.el10 cloudlinux-rollout-1 23 M
cloudlinux-release x86_64 10-5.el10 cloudlinux-rollout-5 27 k
governor-mysql x86_64 1.2-145.el10.cloudlinux cloudlinux-rollout-1 255 k
kernel-headers x86_64 6.12.0-211.7.4.el10_2 appstream 3.2 M
kernel-modules-extra-matched x86_64 6.12.0-211.7.4.el10_2 baseos 1.6 M
kernel-tools x86_64 6.12.0-211.7.4.el10_2 baseos 2.1 M
kernel-tools-libs x86_64 6.12.0-211.7.4.el10_2 baseos 1.6 M
openssl x86_64 1:3.5.5-3.el10_2.alma.1 baseos 1.2 M
openssl-devel x86_64 1:3.5.5-3.el10_2.alma.1 appstream 2.9 M
openssl-fips-provider x86_64 1:3.5.5-3.el10_2.alma.1 baseos 812 k
openssl-libs x86_64 1:3.5.5-3.el10_2.alma.1 baseos 2.2 M
python3-perf x86_64 6.12.0-211.7.4.el10_2 appstream 3.1 M
Installing dependencies:
cl-MariaDB1108 x86_64 11.8.6-1.el10 cloudlinux-rollout-1 9.0 M
cl-MariaDB1108-devel x86_64 11.8.6-1.el10 cloudlinux-rollout-1 8.5 M
cl-MariaDB1108-libs x86_64 11.8.6-1.el10 cloudlinux-rollout-1 199 k
cl-MariaDB1108-server x86_64 11.8.6-1.el10 cloudlinux-rollout-1 25 M
Removing:
kernel x86_64 6.12.0-124.55.3.el10_1 @baseos 0
kernel-core x86_64 6.12.0-124.55.3.el10_1 @baseos 69 M
kernel-modules x86_64 6.12.0-124.55.3.el10_1 @baseos 39 M
kernel-modules-core x86_64 6.12.0-124.55.3.el10_1 @baseos 27 M
kernel-modules-extra x86_64 6.12.0-124.55.3.el10_1 @baseos 1.4 M
Transaction Summary
Install 9 Packages
Upgrade 18 Packages
Remove 5 Packages
Total download size: 198 M
Is this ok [y/N]: y
Downloading Packages:
(1/27): kernel-6.12.0-211.7.4.el10_2.x86_64.rpm 9.9 MB/s | 1.6 MB 00:00
(2/27): kernel-core-6.12.0-211.7.4.el10_2.x86_64.rpm 8.4 MB/s | 19 MB 00:02
(3/27): kernel-modules-extra-6.12.0-211.7.4.el10_2.x86_64.rpm 9.0 MB/s | 3.0 MB 00:00
(4/27): kernel-modules-6.12.0-211.7.4.el10_2.x86_64.rpm 8.9 MB/s | 42 MB 00:04
(5/27): kernel-modules-core-6.12.0-211.7.4.el10_2.x86_64.rpm 5.7 MB/s | 30 MB 00:05
(6/27): cl-MariaDB1108-libs-11.8.6-1.el10.x86_64.rpm 95 kB/s | 199 kB 00:02
(7/27): cl-MariaDB1108-11.8.6-1.el10.x86_64.rpm 478 kB/s | 9.0 MB 00:19
(8/27): kernel-headers-6.12.0-211.7.4.el10_2.x86_64.rpm 19 MB/s | 3.2 MB 00:00
(9/27): openssl-devel-3.5.5-3.el10_2.alma.1.x86_64.rpm 21 MB/s | 2.9 MB 00:00
(10/27): python3-perf-6.12.0-211.7.4.el10_2.x86_64.rpm 20 MB/s | 3.1 MB 00:00
(11/27): kernel-modules-extra-matched-6.12.0-211.7.4.el10_2.x86_64.rpm 17 MB/s | 1.6 MB 00:00
(12/27): kernel-tools-6.12.0-211.7.4.el10_2.x86_64.rpm 24 MB/s | 2.1 MB 00:00
(13/27): kernel-tools-libs-6.12.0-211.7.4.el10_2.x86_64.rpm 18 MB/s | 1.6 MB 00:00
(14/27): openssl-3.5.5-3.el10_2.alma.1.x86_64.rpm 21 MB/s | 1.2 MB 00:00
(15/27): openssl-fips-provider-3.5.5-3.el10_2.alma.1.x86_64.rpm 16 MB/s | 812 kB 00:00
(16/27): openssl-libs-3.5.5-3.el10_2.alma.1.x86_64.rpm 28 MB/s | 2.2 MB 00:00
(17/27): cl-MariaDB-meta-11.8.6-1.el10.x86_64.rpm 11 kB/s | 9.7 kB 00:00
(18/27): cl-MariaDB-meta-client-11.8.6-1.el10.x86_64.rpm 11 kB/s | 8.9 kB 00:00
(19/27): cl-MariaDB1108-devel-11.8.6-1.el10.x86_64.rpm 422 kB/s | 8.5 MB 00:20
(20/27): cl-MariaDB-meta-devel-11.8.6-1.el10.x86_64.rpm 5.6 kB/s | 8.2 kB 00:01
(21/27): cl-MariaDB1011-10.11.17-1.el10.x86_64.rpm 307 kB/s | 7.8 MB 00:26
(22/27): cl-MariaDB1011-devel-10.11.17-1.el10.x86_64.rpm 302 kB/s | 8.0 MB 00:27
(23/27): cl-MariaDB1011-libs-10.11.17-1.el10.x86_64.rpm 89 kB/s | 188 kB 00:02
(24/27): governor-mysql-1.2-145.el10.cloudlinux.x86_64.rpm 129 kB/s | 255 kB 00:01
(25/27): cloudlinux-release-10-5.el10.x86_64.rpm 19 kB/s | 27 kB 00:01
(26/27): cl-MariaDB1108-server-11.8.6-1.el10.x86_64.rpm 441 kB/s | 25 MB 00:59
(27/27): cl-MariaDB1011-server-10.11.17-1.el10.x86_64.rpm 669 kB/s | 23 MB 00:35
Total 2.2 MB/s | 198 MB 01:29
Running transaction check
Transaction check succeeded.
Running transaction test
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: Transaction test error:
file /usr/lib64/libmariadb.so.3 conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/lib64/mysql/plugin/auth_gssapi_client.so conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/lib64/mysql/plugin/caching_sha2_password.so conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/lib64/mysql/plugin/client_ed25519.so conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/lib64/mysql/plugin/dialog.so conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/lib64/mysql/plugin/mysql_clear_password.so conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/lib64/mysql/plugin/sha256_password.so conflicts between attempted installs of cl-MariaDB1011-libs-10.11.17-1.el10.x86_64 and cl-MariaDB1108-libs-11.8.6-1.el10.x86_64
file /usr/bin/mariadb conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-access conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-admin conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-binlog conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-check conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-conv conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-convert-table-format conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-dump conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-dumpslow conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-embedded conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-find-rows conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-hotcopy conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-import conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
file /usr/bin/mariadb-plugin conflicts between attempted installs of cl-MariaDB1011-10.11.17-1.el10.x86_64 and cl-MariaDB1108-11.8.6-1.el10.x86_64
.... and many more
dbctl --version
version 1.2-143
my os info:
NAME="AlmaLinux"
VERSION="10.2 (Lavender Lion)"
RELEASE_TYPE=stable
ID="almalinux"
ID_LIKE="rhel centos fedora"
VERSION_ID="10.2"
PLATFORM_ID="platform:el10"
PRETTY_NAME="AlmaLinux 10.2 (Lavender Lion)"
my kernel:
DirectAdmin,1.703
