Discussion: How do you handle your updates?
Aar
Netherlands
Opinions are divided, yet I was curious about how you handle server updates. First and foremost, of course, critical updates are executed immediately or temporarily mitigated.
But in general, I was wondering how you handle updates? It is, after all, a process that can cause brief downtime in some cases. Do you do this during the day or at night, or do you have special maintenance windows during which this is performed? How often do you perform the general system update?
And how often, in what manner, and according to what pattern do you update DirectAdmin and its components? And do you perform the updates one by one, or all at once with ./build update_versions? Or sometimes a ./build all d? And did you use scripts?
I have my own server for myself and a few clients, and normally I perform the standard system update every week, and the DirectAdmin components a few times a month via the custombuild ('da' command now), and monthly the ./build update_versions. And in case of severity, as soon as possible.
I am curious about your strategy. Maybe we'll learn from it someday. ;)
monthly update, downtime at midnight.
If you plan to do this ensure you write in your ToS to not confuse your customer, someone hate it to downtime every month.
Just call it 99.9% uptime. 100% uptime simply doesn't exist.
nd you're choosing the system update and the DA component update together?
update components from directadmin isn't cause issued that much, you can safely enable the automatic update.
directadmin update isn't long-downtime, only issued when you update the OS package and required full-reboot to get new kernel loaded.
that's why I called monthly downtime, because it's really down... around 30-120second.
I normally always run the da build update and then da build update_versions command after it.
How often depends on how often there are updates and how important they are.
Every other week. We use Ansible for both DirectAdmin and OS updates + automated reboot handling.
We collect all updates a few times a day and catalog them automatically in three groups that represent updates that can run anytime, updates that require a service restart and updates that require reboots.
Resource hungry updates (php compile etc) are thrown in a bucket so it doesn't start compiling php on dozens of servers at the same time.
Compiling php might take a while, but the actual downtime is a few seconds so this runs often during the day.
Reboots are scheduled in default maintenance windows, unless it's a redundant server (e.g. 3 webservers behind a loadbalancer). Those are also done during the day in low traffic moments (which are depending on our monitoring).
I have my own server for myself and a few clients, and normally I perform the standard system update every week. If anyone wants to see details on my update routine, I also update the DirectAdmin components a few times a month via the custombuild (da command now), and run ./build update_versions monthly. In case of a critical security issue, I update as soon as possible.
I handle critical security updates immediately, but everything else goes into a scheduled maintenance window during off-peak hours. I update the OS weekly, DirectAdmin every few weeks, and only run a full rebuild when it's actually needed. I also make sure I have current backups before any major updates so I can recover quickly if something goes wrong.
