http flooding / AI bots / DOS attacks
freakie
Apeldoorn, Netherlands
I run a Licensed DirectAdmin server for some friends and family.
As everyone else, we also get HTTP floods, AI bots, bots that scan for specific versions of software of OS and or Website.
Does DirectAdmin have any protection against this?
Im thing about using abuseip database, perhaps using nginx_apache ?
Would that help or are there any suggestions ?
its getting out of hand, just like spam several years ago.
You can use CSF (for flood and rate limiting) along with additional blacklist (like abuseip) to reduce bad bots and IP address
Ssometimes blocking some countrys like CN/BR do help also
and those website are behind CDN like cloudflare too ? If this case, nginx ratelimits is good idea. But you need to customize by yourself.
if it your site, please config ratelimits at cloudflare side.
At this moment we experience bot attacks especially to phpBB forum software, there are countermeasures which will help, there is a complete topic about it on the phpbb.com forums.
Next to that since not too long, we experience attacks from Google Cloud LLC ip's, we got annoyed about the logs and just block all Google Cloud ip ranges. Next to the blocks which CSF also does for example on too many connections from 1 ip and blocklists like abuseipdb.
But they use loads of those ip's, so we blocked them all.
We try to filter as much as possible with csf and cloudflare but the past days have been terrible.
I'd say 90% of web traffic is pure garbage. Dead internet theory.
on Cloudflare, set ratelimits to 75request / 10sec, that should reduce some massive ddos from one-ip. For me I go with "120req/10s", because I already have ratelimits on nginx side, so it's fine for me.
Google Cloud IP abuse is off the charts lately. It's almost rivalling the amount of bad traffic I get from Digital Ocean.
I have a rule to pull the 100% guaranteed bad IPs from AbuseIPDB. I apply that at the firewall level. I block all xml-rpc.php and rate-limit wp-login.php.
I think we're going to need a good proof-of-work system since the current abuse I'm seeing is 1 request to a unique (and valid) URL from an IP, and then never see that IP again. I've been tracking a botnet and they can burn through 50k+ IP addresses a day with ease. Checking them, most do not show up on AbuseIPDB, so forcing the requests to be CPU expensive might be the only option.
Hi
I've wrote my own software to detect abusive behavior and redirects the IP to a captcha page.
The captcha page is very lightweight, very simple, I wrote it myself, so it does not cause a resource burden on our servers.
This way we don't block any IP.
Kr
Dries
Is this in PHP? I have explored doing something similar, but with just raw Apache everything feels a bit tricky. None of the workarounds seem reliable enough.
LiteSpeed has this built-in, which is nice, but I only run LiteSpeed on a few machines.
@adam12
I never using mod_evasion, but you can try it. like around 120req/10second, this ensure prevent the false positive on the normal client
Is this in PHP?
Yes, it is PHP.
If you know a bit about programming, I suggest to rewrite it yourself.
I first wrote it to block POST requests, all POST requests are always blocked.
You have to make a IP whitelist for automated POST requests.
Recently I wrote a perl daemon that regex scans apache logs and blocks certain IP's that are behaving abusively.
This way false positives have a way to get whitelisted again via a captcha page.
I have it here:
If someone is using it, please let me know, I will update the code.
In the last 3 years, I've been updating it often.
For example, i've made it the IP whitelist logic more performant.
Kr
Dries
